  1. Exact model and year of your car please - and in this case engine please?
  2. You need to read the Lost Radio Code FAQ...
  3. You did not read the Lost Radio Code FAQ... "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  4. The order sounds correct to me. Check the spark plug for cracks (including hairline cracks).
  5. P2181 Thermostat Blocked - Implausible Possible fault cause: ♦ Thermostat blocked open ♦ Faulty engine temperature sensor
  6. Model/Capacity in Liters (US quarts) (approx.) 911 Carrera (3.4 liter engine) 8.50 liters (8.98 US quarts) 911 Carrera (3.6 liter engine) 8.25 liters (8.71 US quarts) Boxster 8.50 liters (8.98 US quarts)
  7. Not necessarily. Airbags don't take much power at all. Best to double check where your draw is.
  8. Then its time to monitor the battery current draw (amp meter) -- then remove one fuse (at a time) looking for the large current draw going away. That will be the circut with your draw or short.
