  1. Check the pulleys - the bearing do go bad and then they wobble. Sometimes when they break they take out the alternator too - so best address this asap.
  2. Check the connections at the starter for corrosion as well as the engine ground strap. BTW... how old is your battery? Have you had it both load tested and also had the specific gravity of each cell checked?
  3. Try 9096 or 9094 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  4. Loren
    Rev Limiter
    Correct - it will also not protect you if you spin the car and don't get the clutch in fast enough (you can actually run the engine backwards by spinning the car backwards too).
  5. I have seen that plug cracked from someone shoving the headlight in too hard without lining it up first - several times.
  6. Try 9044 or 9042 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  7. :welcome: Usually and ignition switch manifests itself as many other electrical problems. So, it absence of that I would suspect the fuel pump - assuming non of the aftermarket installed components are causing the problem.
  8. Try 5152 or 5150 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  9. ... or the small magnet on the Tip shifter fell off and jammed in the mechanism.
  10. :welcome: and :thumbup: Great quality vidieo!
  11. Loren
    Rev Limiter
    8200 RPM
  12. Looks like coolant to me. Check the hoses and water pump and of course the coolant tank cap.
  13. I think he is asking about the air intake and purge air vents on the outside of the Boxster.
  14. Try 4866 or 4864 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  15. 1. I do not know - you will need to test it. 2. The Violet wire coming from the instrument cluster B4 (Blue plug) is the fuel sensor. 3. Use the reverse connection under the drivers seat. See the TSB on the Traffic Pro install for details. 4. Gray Pink wire (several to choose from). Try to pick one that is not already in use.
  16. PIWIS updates are $12,000 a year.
  17. You can purchase these uphostery and trim tools from Harbor Frieght. Unfortunately, we don't believe there's Harbor Freight over in Europe. They are on the web - so they likely ship anywhere. http://www.harborfreight.com/cpi/ctaf/disp...temnumber=67021
  18. Can you tell us what you are trying to connect? Shift computer? Lap timer?
  19. You posted in a 4 year old thread which is likely why you are getting no response. I don't recall anyone posting about a "screw on the oil filter housing" - not on V8 engines. There never has been one on the V8 engines (this thread is about the Cayenne Turbo (V8). Only the V6 Cayenne has the screw on the oil filter housing.
  20. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will ONLY answer radio code requests in that one thread linked at the end of the FAQ. This topic is now closed.
  21. Try 8272 or 8270 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  22. Try 8310 or 8308 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  23. Check the coil pack, electrical connector and spark plug on cylinder 3.
  24. Porsche's coolant is made by Elf.
