  1. Chances are that your radio was repaired at some time by someone other than Becker. So, sorry no know will be able to fix the radio other than Becker.
  2. Did you use the procedure in the Lost Radio Code FAQ? If not, then please do so and repost with the correct serial number.
  3. DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. This topic is now closed.
  4. Please use the Lost Radio Code FAQ to get your readable serial number and then post it here.
  5. I need your radio serial number. See the procedure here: Lost Radio Code FAQ
  6. Wow this is the fourth message you have posted about the same issue. You need to re-read the board Guidelines/Rules: (that you agreed to when you registered here) -- "Please post your messages in one forum only. Crossposting, double posting, triple posting, etc. are all a waste of time and valuable resources. If you post the same message in multiple times or in multiple forums, we will delete the ones we feel are inappropriate."
  7. 174 Camshaft adjustment, bank 1 322 Timing chain out of position, bank 1 Yes, you have a sizeable problem. If the car has not been run then any additional damage may have been averted. If not, then you likely won't know until you open it up. Sorry...
