  1. 958 044 801 23 Roof Edge Spoiler with high mount stop light -- US MSRP $858.75 (unpainted) By "under floor panels" do you mean under body protection or do you mean the stainless steel front spoiler?
  2. P2198 Lambda correction downstream, bank 1 – rich/lean control limit exceeded Possible fault causes: - Leakage in exhaust system between the two oxygen sensors - Oxygen sensor upstream faulty (contaminated/aged) The most common fault cause is a leakage between the two oxygen sensors, resulting in the sensor downstream measuring more residual oxygen in the exhaust than the sensor upstream.
  3. This topic is closed. DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  4. Did you read the first post in this thread?
  5. RFM was not suggesting switches but the connectors in the door frame.
  6. Yes, the belts use a pyrotechnic charge to trigger in an accident.
  7. I think is asks that if you say you are replacing - rather than installing new. Try removing the radio -- then installing new.
