  1. :welcome: What did you use to get that fault code? The Porsche code is: Fault code 4440 Steering-angle sensor Possible cause of fault: - Short circuit to ground/B+ or open circuit - Steering angle sensor calibration incorrect - Wiring! plug connection faulty - Steering angle sensor faulty I would start by putting a PST2 or PIWIS tester on the car and calibrate the steering angle sensor. Then clear the code and see if it comes back.
  2. Try 9606 or 9604 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  3. :welcome: Search is your friend... Cayenne Front Pads and Rotors DIY
  4. Are you buying from a car dealer or private party? Are you in San Francisco?
  5. Porsche (Bosch) does not publish those since they consider DMEs as FRUs (Field Replacement Units). Porsche does sell rebuilt exchange DMEs for your model year.
  6. Have a look at TSB 4/074440 Approved Tires, Wheels and Spacers (As of 2003 up to 2006) -- dated Nov 5, 2007. It has everything you need - including pictures of the wheels.
  7. Please do a search - this has been covered many many times...
  8. The better driver is always faster. The power to weight ration will always favor the C2.
  9. Search is your friend... http://www.renntech.org/forums/index.php?s...st&p=110908
  10. MY91_DME_Engine.pdf
  11. :welcome: 996.624.117.01 Actuator (rear) -- US MSRP $89.71 If someone quoted you over $89 then they a gouging you with a price over MSRP. Did you email or call Sunset Imports (Porsche Parts at Dealer Cost)? Sunset Imports sells at dealer cost plus 15%. Link at the top center of page...
  12. Did you read the FAQ?
  13. :welcome: Model and year of your car please?
  14. Only 'approved' MOTUL engine oil by Porsche: MOTUL 8100 X-cess 5W-40 5W-40 MOTUL 8100 X-clean 5W-40 5W-40
  15. No - spring rates and damper rates changed due to weight differences (3.4 liter to 3.6 liter).
  16. Sorry, you will need the Durametric software, a PST2 or PIWIS tester to read the air flow over the MAF at idle and at 2500 RPM.
  17. Has the MAF been tested. P0102 says it is not connected.
  18. Try 1289 or 1287 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. Try 9521 or 9519 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. Try 7167 or 7165 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  21. P0455 Evaporative Emission System Leak Detected (large leak) Possible cause of fault - Tank cap not tightened correctly, faulty or missing - Mechanical fault in EVAP canister purge valve (does not close fully) - Leakage diagnosis pump leaking internally (membrane) or externally - Mechanical fault in EVAP canister shutoff valve (does not close fully when power is supplied) - EVAP canister shutoff valve connections leaking - Tank system (including pipes) leaking I would reset the other codes and see if they occur again.
  22. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  23. 999.170.201.90 Spark Plug (14 FR 7 LDU) -- US MSRP $11.36 each This is an updated spark plug as spec'ed by Porsche.
  24. Most common problems like this are a loose connector on the oil pressure sensor or a bad sensor.
