  1. Ok - you follow this link to a complete parts list. http://www.porsche.com/usa/accessoriesands...partscatalogue/
  2. Left or right side. BTW... when Porsche does not sell a part the part number is blank in the listing. And, my listing was updated 3 days ago (Oct 2009 Listing).
  3. That is why I always count threads (from the end). If it worked before the short shifter it should work after the short shifter.
  4. 996.612.674.00 Wiring harness mirror -- US MSRP $46.36
  5. Try 0784 or 0782 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. Did you read the instruction here and B&M's short shifter instructions? The threaded end of the cable is the adjustment.
  7. Likely Porsche MotorSport parts - they do not show up in the normal parts list.
  8. :welcome: You likely could not find it because Porsche uses an strange name for it "oddments tray". You can find the TSB instructions to fix it here.
  9. Less than 4 hours since your post and no responses - please have a little patience. Is this the light you mean?
  10. Things to check: Short circuit in signal wire to ECM ground or housing ground. Short circuit in signal wire to ECM ground or housing ground. DME control module output stage short to ground. Possible causes: - Wiring harness - Oxygen sensor - DME control module
  11. Your reverse cable adjustment (blue cable) is off. You will need the alignment tool to adjust. As I recall the tool is just a few dollars.
  12. :welcome: Please post your request once and only once (see the board Guidelines/Rules). Your second post has been removed.
  13. Yes, MY02 Carrera is still pre-MOST.
  14. 955.552.261.01.62W Shift gate (satin aluminum) -- US MSRP $211.80 For better pricing try Sunset Imports (Porsche Parts at Dealer Cost - link at the top of page).
  15. Try 7817 or 7815 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. I am surprised Porsche has not gone after these people claiming to sell a "PIWIS' cable. The specs read like a rip off of the Durametric software.
  17. Very little difference from MY99 to MY00. C2 became egas in MY00 - MY99 was traditional cable drive. C4 was egas for both MY99 and MY00.
  18. Please read the FAQ - we need your radio serial number - per the method in the FAQ. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. I do not know about gas unless you know of folks that have similar problems. Yes, you can erase them and see if they come back. BTW... new plugs and coils last year does not mean that one or more may have failed.
  20. Usually, in these instances it is plugs, coils, and the electrical connectors on the coils. I would double check them all.
  21. Are you sure there are not more faults - for specific cylinders? What scan tool are you using?
  22. The radio is on unswitched power (always has power applied to it). You should be able to turn it on (and off) without the key. Unless someone has reqired it that is how it should work.
