  1. Unless they can be re-welded (to stop the rattles) you will either have to find a used set or buy a new muffler.
  2. All answered in the FAQ...
  3. Looks like you need 997.613.133.00.FMH Combined switch (PSM only) -- US MSRP $79.34
  4. Hi Loren, Thanks for the prompt reply. Here are all the codes from my options sticker: C02 - Equipped with catalytic converter XLA - Chrome Exhaust Pipes 267 268 288 - Headlight Washers 342 - Heated Seats 435 - Sport Steering Wheel 446 - Colored Wheel Crests 502 507 601 680 - Bose Surround Sound System As you can see, there are several that I have not figured out. Cheers, Chuck Sorry, but I don't see PSM (476) which you said you had. Perhaps it would be best if you PM me your VIN.
  5. Try 0536 or 0534 Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. :welcome: You need to look at options sticker and see which of the listed options you have. Or, send a PM with you VIN and I will look them up for you.
  7. Try 0182 or 0180 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  8. Try 4604 or 4602 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  9. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  10. No, not if the radio worked before. The only time it should need to be re-programmed is if the radio is replaced with a different one.
  11. :welcome: If you got to the top of any page their a menu called "Documents" - click on that and choose " MY03-MY10 Order Guides" - then select the year you want and then the model.
  12. Yes, as I said inspect all swaybar mounting points.
  13. As I recall the wire loom goes up behind the instrument cluster and then over to the fuse panel side and then passes into the door.
  14. Look at the swaybar mounts to the chassis - you will likely need to remove the plastic belly cover.
  15. I would start with looking for loose swaybar mounts or upper strut mount bolts.
  16. Recheck your connections and make sure the 3 connectors are in place and locked down. BTW.. you can replace just the ODO stalk - do a search here for the part and process.
  17. Sorry, it will not fit a narrow body car or a C4S. Turbo rear lids are a different length. There are a number of aftermarket supplier that make a Turbo lid "look-alike". MAShaw is one.
  18. Try 7499 or 7497 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. Try 0330 or 0328 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. Please state your location - and English if possible. Thank you.
  21. Sorry, but the book is wrong. That was true on the older cars."C02 = Rest of USA (in 1991 became all of USA)" (from Porsche's VIN and option explanation). My car is a MY99 California car and it has a C02 code.
  22. Sorry, but this all speculation - I highly suggest that you have a good Porsche shop inspect the car and find out what really is the source and cause of your problem(s).
  23. I just talked to the folks at Sunset Imports - they said they got large influx of emails overnight and they are catching up. Bob (McCarthy) said you should get a reply sometime today.
