  1. Please do not double post (see the board Guidelines/Rules that you agreed to when you registered here). Please try our search - many questions have been answered before - including this one. Can this be fixed or do I have to replace the entire cluster
  2. Try 5233 or 5231 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  3. Thanks Loren. I agree 110% on using the right fluid in the auto tranny. Any info on the TC and Diffs oils? SAE weights, grades, etc? Hint... did you you check the TSBs?
  4. Depends on how big "you" are and if you can reach it without putting it on a lift.
  5. Try 6033 or 6031 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. Try 2989 or 2987 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  7. Model and year of your car please...
  8. If you are talking about fuse B2 - then the answer is no - just the radio.
  9. :welcome:
  10. :welcome: You will find search is your friend here... Pre-02 Aero Kit Wing Adjustment
  11. I suspect so - I recall getting the same error on my PST2 when I run that test. My guess would be that it needs to reset the controller during the test.
  12. P1276 Signal Delay Time for Oxygen Sensor Aging, Bank 2 – Above/Below Limit Possible fault causes: - Oxygen sensor ahead of TWC - Leak ahead of TWC or in the area of the oxygen sensor after TWC - Wiring (oxygen sensors exchanged) I would highly recommend the Durametric software, a PST2, or PIWIS to read and reset fault codes on Porsches. If this is the only code you get then the problem is only bank 2. I would erase it and see if it comes back. If it does, you likely have a bad O2 sensor before the cat.
  13. 000.721.950.71 Connecting hose -- US MSRP $40.05
  14. Yes, if I get 12,000 miles out of my rear tires I feel fortunate. Your driving style can affect tire wear - but I still would expect to wear out two sets of rears for every one set of fronts.
  15. A single beep means that one (or more) alarms zones are open.
  16. I have no problem (and any moderator can also pin) - but I would prefer a "known" solution before pinning. I think you kind of need to have PST2 or PIWIS actively running on the car at the exact time this occurs. Then look at the fault and potential causes.
  17. That sounds perfect. My Boston area dealer tech wasn't able to code the computer. All I want is the outside temp. Could you post instructions for the one-wire mod? Thanks very much. Please do a search as this items has been covered many times. They need to enter the car's model code in the DME or no programming can be done. As a dealer they should already know this. Try another dealer or shop.
  18. Manual bleeding like that can take a week - so top it up daily.
  19. See the links in the post just prior to your post.
  20. Loren
    Appraisal
    Please tell us what Bat Area? We have members from all over the world.
  21. Try 4683 or 4681 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  22. Back on the original posters topic please...
