  1. If it is just those two cylinders then the problem is in: the spark plugs (loose?), or the coil packs (cracked?), or the electrical connectors (damaged or loose).
  2. If you only get a misfire on cylinder 1 and cylinder 4 - how could it not be related to just those two cylinders (which by the way are opposite sides of the motor)?
  3. Be sure and check the part numbers and make sure they are putting in the NEW parts and are not using up old stock of the older parts. The latest part number (as of 2 weeks ago) is: 948.602.104.06 I would check your last invoice too.
  4. Since one tube is leaking you might as well check them all and pull a spark plug or two and see what they look like.
  5. Yes and no. Since the partial power seats are a subset of the full power they might work but just have extra connectors. Or, the connectors might not match up at all. Since I have not tried this perhaps someone that has can comment...
  6. Try 5610 or 5608 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  7. Yes, the TSB covers all years and the coil packs have been updated 2 or 3 times.
  8. If you have a misfire then there should be fault codes or pending fault codes. You will need a good reader like Durametric, a Porsche PST2 or PIWIS tester to really see what is going on.
  9. Fault codes 10,11,26,27,39 Ignition circuit, passenger Possible cause of fault - Short circuit to B+/ground or open circuit in the wiring between the passenger airbag unit and the airbag triggering unit - Passenger's airbag unit faulty - Triggering unit for airbag faulty
  10. Try 5233 or 5231 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Unfortunately, neither of these codes worked for me. Thanks anyway, Quiddity319 PLEASE read the FAQ.
  11. Or maybe just a motor that hasn't been cleaned in 7 years... I would clean everything up then look and see if there is a leak.
  12. Correct - do not drive a car with a flashing CEL. It will damage the cats. Without reading the fault code(s) it is hard to tell.
  13. Try 1280 or 1278 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. That's just it....no one seems to provide a clear answer only opinions. What does the owners manual recommend? You can download the Owners Manuals here
  15. Please do a search here - oils have been discussed here ad nauseam...
  16. Item 3 - 986.397.027.00
  17. Try 5406 or 5404 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  18. I think this is the o-ring he is speaking about.
  19. Loren, Can you share the differential Oil specs/recommendation for 04 CTT... Thanks This is why it pays to be a Contributing Member here -- viewing access to all TSBs.
  20. The adjustment procedure is in your Owner Manual. ;)
  21. :welcome: Is this a US/Canada car or RoW? Are you sure the car is a MY1991 and not 1990? There was a 1MX in MY90 that was burgundy. No MX I can find for MY91.
  22. Try 3102 or 3100 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  23. Try 5881 or 5879 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  24. We have the latest that Porsche has sent us (we have a subscription - that we pay for).
