  1. Update: I have seen but do not yet have a copy of the TSBs for each model upgrade. (I will post these in the Contributing Members TSB section for viewing when I get my copies.) The procedure requires a dealer connected PIWIS tester to validate the upgrade code and allow the programming - so you will need to have the dealer/OPC perform this upgrade.
  2. Have your ignition coils been replaced? My guess is you have one more that are cracked.
  3. Check for: - loose spark plugs - cracked coil packs - coil pack electrical connector not snapped into place The last item is the most likely cause.
  4. Yes, a Porsche dealer can look up service records of service actions done at other Porsche dealerships.
  5. No gaskets. See the write-up here
  6. All Porsche PSM fault codes are in the 4000 and 5000 series. I suggest you get the car scanned with the Durametric Software, a Porsche PST2, or PIWIS tester.
  7. All the approved tire sizes are covered in the TSB - Winter Tires and Wheels.
  8. :welcome: Are you referring to the front or rear trunk? Both have microswitches that sense the position.
  9. Try 5744 or 5742 Tried both codes. 5744, unit sat on wait for about an hour after pressing scan up button, then returned "code". Second code 5742 did nothing, stayed on "code". Your thoughts please. If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Try 5744 or 5742 Tried both codes. 5744, unit sat on wait for about an hour after pressing scan up button, then returned "code". Second code 5742 did nothing, stayed on "code". Your thoughts please. If you have not already read this FAQ - please do so... Did you read the FAQ? Did you verify your serial number as the FAQ instructs?
  10. The Retail Price Search feature (for our Contributing Members) has been updated to reflect January 2010 pricing for the US (only). We try to update this on a monthly basis as the price lists come available to us. For January 2010 the price lists support: US: 240,543 parts Thanks again to Contributing Member Porschelibrarian!
  11. :welcome: Model year? US/Canada car of RoW?
  12. Please double check this with your dealer - PNA986KITCBL Rear Speaker cable -- US MSRP $91.70
  13. :welcome: It would be very helpful if you would give the model and model year of your car, the stereo option (M490 or M680) and whether it is a US/Canada car or RoW. Thanks.
  14. Try 1826 or 1824 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  15. RennTech.org Store at Amazon.com Look for the Bentley Boxster Manual.
  16. Please post this in the proper thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  17. Try this... http://www.bombaydigital.com/boxster/projects/window/
  18. Try 5744 or 5742 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. Try 1306 or 1304 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I tried 1304, 1306 and 1302 didnt work any other suggestions? Yes, read the FAQ.
  20. Try 1306 or 1304 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  21. 986 559 983 01 was replaced by 986.559.983.02 and 986 559 98401 was replaced by 986.559.984.02
  22. Normal - emissions air pump. Sounds like a mini vacuum. It might also run for a few seconds when you come off the freeway and idle.
  23. Did you look at TSB 1/02 6658 Aerokit II -- Aug 23, 2002 (in the Boxster 986 section)? Those should be correct - or whatever they were superseded by.
