  1. Always use the latest part number seal. Right now that is: 997.101.212.01
  2. Thanks for your help, it seems that somehow mechanic figured it out but just to confirm I will be pleased if someone can write firing order and cyclinder numbering. Firing order 1−6−2−4−3−5 Cylinder order: Facing the engine - back to front - left side 1-2-3 Facing the engine - back to front - right side 4-5-6
  3. The radiator fans run if the AC is on?? I don't remember if it was or not. I will check it. If the AC is off should the cooling fans be off on cold start up? Yes, that is correct.
  4. Try 5242 or 5240 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  5. Umm... they run all the time if the AC is on.
  6. See the links in the post just prior to your post. Loren, Do you know if this DIY works on 2003 C4S? Regards The wire colors are different -- but it works.
  7. Forgot to ask you. Where is the paint code located on the car? Thanks Mike Please check your owners manual for locations.
  8. Try 0891 or 0889 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  9. Carrera Paint Colors Do a search for online suppliers referenced here or go to a dealer.
  10. Sorry, I forgot about stating that also -- stubenhocker is correct you will need to charge the battery.
  11. If you have AC - then that is the correct belt.
  12. More... http://www.porsche.com/microsite/intellige...rmance/usa.aspx
  13. By law batteries must be shipped without acid. You will need to get some sulfuric acid to activate the battery from an auto parts store or shop.
  14. Try 0384 or 0382 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  15. Try 0999 or 0997 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Try 4353 or 4351 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  17. Try 0030 or 0028 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  18. Porsche uses Teflon tape or felt tape depending on the problem.
  19. Try 1369 or 1367 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. Please post this in the proper thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  21. Those are not oil coolers but engine water/coolant coolers. If you do a search on the board you will find several solutions using screens from Boxsters to GT3s. With the retains frame around the bumper openings it ought to be fairly easy to attach screes to the back side of the bumper.
  22. I think I would go the GT3 route. On the 996 (and 007-1) the center radiator is for the Tiptronic. The GT3 should have the correct hoses too.
