  1. Try 2902 or 2900 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  2. Charge pressure sensor is in the intercooler (intake pressure side) pipe. I think the ambient pressure sensor box is behind the dash/front console. Have you looked for actual values reported for each of these on the Durametric? Could narrow your search if one is zero or if charge pressure does not change with rpm.
  3. The adaptation values can be read out with the Porsche System Tester 2 and I suspect Durametric can read the same. The key to the adaptation values is as follows: RKAT = Adaptation in range close to idle - Cylinders 1 - 3 RKAT2 = Adaptation in range close to idle - Cylinders 4 - 6 FRAU = Adaptation in lower load range - Cylinders 1 - 3 FRAU2 = Adaptation in lower load range - Cylinders 4 - 6 FRAO = Adaptation in upper load range - Cylinders 1 - 3 FRAO2 = Adaptation in upper load range - Cylinders 4 - 6 FR = Oxygen sensor - cylinders 1 - 3 FR2 = Oxygen sensor - cylinders 4 - 6
  4. :welcome: P0732 Gear monitoring, 2nd gear - signal implausible Possible causes: - ATF level not OK - Solenoid valves - Valve chamber - Transmission P0740 Fault, torque converter clutch - present Possible causes: ATF supply - Torque converter - Pressure regulator 4 (hydraulic) - Electrical triggering to pressure regulator 4 - Hydraulic control unit Sure looks to me like you should start by making sure the ATF is at the proper level. Then run the Tiptronics tests with a Porsche PST2 or PIWIS tester.
  5. :welcome: P1136 Pressure Comparison Charge Pressure - Ambient Possible fault cause: - Charge pressure sensor - Ambient pressure sensor - Wiring harness
  6. Try 0845 or 0843 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  7. Try 8799 or 8797 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  8. The Boxster manual will not be correct for 996TT - completely different engines. See the diagram below for the 996TT:
  9. The latest baffle for all 3.4 and 3.6 liter engines is 997.107.243.00 Baffle -- US MSRP $35.57
  10. Only thing I can think of is a salvage yard. See the links here Oklahoma Foreign is the best I've used.
  11. Try 9608 or 9606 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Thank you for your quick reply, Loren. I tried the first stereo code you gave me: 9608, but I got the word to "WAIT". So then I turned the stereo off and on again, and turned the car ignition off and on multiple times, but I still have the stereo "WAIT" message showing. What do I do now? DO you also need this info: Becker 1 Serial # 250 14597, TYPE: 4462, 24/99 ? Thank you for your time. Cynthia Did you read the FAQ? I think not... Loren, Thank you for your assistance. I tried both codes 9608 & 9606 (just as I was instructed in the link you provided), but neither of those codes worked for my stereo. Do you have any more suggestions for other numbers that I may try? Thanks again for all your help... -Cynthia There are suggestions in the FAQ.
  12. Sorry, my bad typo (fixed now) - that is the correct part number.
  13. Sorry, but I am still confused. Those two diagrams should be all the parts that you can order. Are you saying the piece in your first picture that looks like it is epoxy'ed into place?
  14. The correct part number for the intermittent wipers relay for 996 Carrera is: 996.615.103.00 -- and it is $20 cheaper than the Boxster part.
  15. It won't fit around the headlights or fenders. There are some aftermarket replacements that look like a 997-1 bumper but do fit 996.
  16. Try 2939 or 2937 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  17. PSM Fault code 4206 -- Speed sensor, front left Incorrect signal from speed sensor Possible cause of fault - Toothed ring/speed sensor soiled or damaged, wheel-bearing play too great - Pick-up due to faulty shield - Speed sensor faulty - Control unit faulty
  18. I think it needs quite a bit more detail to make this a DIY Tutorial. DIY Tutorials need to be more of a step by step.
  19. Can you tell me the item number from the diagram above? (click to enlarge the diagram)
  20. Rarely are TSBs performed for free after your warranty has expired - unless, of course, this was previously reported while under warranty.
  21. Please clarify if you are talking about the wing itself or the rear deck lid. Thanks.
  22. The only MAF for the 996TT is 996.606.124.00.
  23. Did you search the Cayenne TSBs - there are two on wind noise: 8/05 6440 Whistling Noise From Door Window Area -- dated Jul 1, 2005 8/04 5730 Wind Noise In The Upper Area Of The Front Door Window -- dated Oct 11, 2004
  24. Sorry, but his works fine for me with both Firefox and IE8. What browser are you using and have you tried clearing the browser cache and cookies?
  25. Try 9073 or 9071 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
