  1. Then take the battery out of the circuit to charge it (disconnect the cables to the car).
  2. Try 9552 or 9550 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  3. If you are just looking for options - any OPC can give you printout of that.
  4. Why would that not be covered under warranty? (unless of course you hit something) 997.363.162.02.12H Rear Wheel 11 J x 19 ET 51 - Speed Yellow -- US MSRP $2575.82 (plus mounting and balancing)
  5. Did you read the FAQ - I think not.
  6. Replacing the Ignition Switch 96 Ignition Switch replace (just the switch) with pictures
  7. Yes, it is above the third radiator in my car.
  8. Mk2 cars have different air ducts. Will they fit on a mk1 car? probably Let us know what you find...
  9. That is actually a kit for the X51 for the mk2 - I hope everything fits.
  10. I don't know for sure but I'm pretty sure the cutouts in the Mk2 bumper will not be located properly for a Mk1 exhaust. Maybe some adjusting - maybe Mk2 tailpipes will work?
  11. That's it - likely just a little stuck.
  12. As I have said many, many times here PLEASE READ THE FAQ - all these questions are answered int he FAQ.
  13. Try 8655 or 8653 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  14. Try 6857 or 6855 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  15. Yes, PLEASE read the FAQ.
  16. The front fenders won't line up with the front bumper unless you replace them too. The shape of the headlight openings changed. Also, I am not sure the rear bumper tailpipe openings will line up - I think they will be close but you don't want a hot tailpipe touching the plastic bumper.
  17. You might want to talk to the EVOMS folks. It thinks there is a program problem in the DME.
  18. Try 0859 or 0857 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. The card is likely from a replaced radio - perhaps long ago. The readout serial number is always correct. Try 5307 or 5305 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. I would get hot - let it cool slightly and then drain it. You want to get any moisture and condensation to burn off and get carried away in the old oil.
  21. You should also ask for an opinion from PCNA (Porsche Cars North America).
  22. Probably not worth the trouble (IMHO). Doesn't do much - and most people I know have removed them.
  23. Have you tried locking and unlocking the door using the metal key? That should reset the remote functions.
