  1. Did you order the longer bolt too? I think the bolt is longer on the 3.8.
  2. I think that is fuel tank vent - other side goes to the charcoal canister - correct?
  3. Drivers, drivers, drivers - a cloned image will not work on many laptops because Windows 3.11 use specific hardware drivers. We also do not condone making copies of copyrighted materials.
  4. pin 2 is power pin 1 closes the valve pin 3 opens the valve I think it goes in steps so it may only move a small amount each time you ground pin 1or 3. Check continuity first - most bad valves are open.
  5. Is this a US /Canada car or RoW?
  6. I think the part you are looking for is: 999.590.046.40 Disc cam -- US MSRP $0.38 each
  7. Try 6518 or 6516 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  8. Try 1072 or 1070 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  9. Try 9583 or 9581 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  10. Please post this in the proper thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  11. PST2 or PIWIS tester or Durametric tester will all measure all fluids accurately.
  12. SECOND WARNING! Please post this in the proper thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  13. Please post this in the proper thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  14. Windows 3.11 (hint before Windows 95) and you must have the Bosch interface card for it to work.
  15. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Please post this in the proper thread. Please read this and follow the instructions... Lost Radio Code - FAQ, PLEASE READ THIS FIRST I will only answer radio code requests in the one thread linked at the end of the FAQ. This thread is now closed.
  17. Go through the engine access panel behind the seats.
  18. Use the minus button on the HVAC controls and turn the HVAC (and fan) off. It will show "oFF" in the display when it is off.
  19. Porsche just raised prices today (no joke) - so if you find someone with one in stock - they bought it at the old (lower) price.
  20. You can read and reset all the fault codes. The way I understand it in version 6 software Durametric added programming of special functions found mostly in the newer cars (997-1 and newer). So if you have an older car (9x6 series) you would not have many (if any) of these capabilities anyway.
  21. http://carboncow.net/index.php?option=com_content&task=view&id=16&Itemid=97
  22. Try 3190 or 3188 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  23. Take the belt off and check all the pulleys for wobble. Replace any that wobble.
