  1. Model, year, transmission type?
  2. Yes, you are looking at a fault for the switch by the door sill. Best open it up and see if the switch or wires are damaged.
  3. Folks - please do a search - replacing the amp/radio with a double DIN units has been covered here many many times...
  4. Sorry, you can only reset that with the Durametric software or a Porsche PIWIS tester.
  5. What does Durametric show since you replaced the front trunk microswitch?
  6. Try 0924 or 0922 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  7. Instead of guessing I suggest you find someone with the Durametric software, a PST2 or PIWIS tester -any of those will tell you exactly where the fault is.
  8. 996.613.219.10.EWC steering column switch (w/cruise and OBC) -- US MSRP $276.54 The install video is here
  9. can you tell me how to find the antenna in the rear roof spoiler Please give our search a try.... http://www.renntech.org/forums/index.php?/topic/22668-removing-top-of-spoiler/page__view__findpost__p__118245
  10. For the ABS check the MAF and the brake lights (switch) - if either of these are bad then you will get both ABS and PSM failures. If both are okay then I think you may need a PST2 or PIWIS to diagnose further.
  11. Part number changed to: 999.507.657.09 Floor Cover Clip (6 per car) -- US MSRP $0.87 each item 3
  12. Um... ABS 5.7 did not go into the C2 until 2002. Is this a C4?
  13. What year C2 chassis (so I know which ABS system it has)?
  14. Please do a search here - this has been covered extensively here many times...
  15. Try 4510 or 4508 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Sorry, you will need to replace the turn signal switch assembly in the steering column.
  17. You need to take it off and see where the is. Perhaps it came loose but my guess is either the hose is split or the fitting is.
  18. 955.552.383.01.62W Cover in satin aluminum -- US MSRP $61.13
  19. :thumbup: You are welcome. Any pictures of the differences?
  20. Year and model of your car please? Do have NAV? which option? I am looking for the same thing as the original poster. My car is 2004 Cayenne S with Nav. Thank you. Item 18? If so I will need to know if you have seat heating or not.
  21. I'm sure it is just centered the same as the Boxster only logo.
  22. Sorry, to hear that MSRP on the part is only $205.
