  1. You didn't read the Lost Radio Code FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  2. 8N2 837 016 B door lock with door contact switch - right rhd - US MSRP $282.94
  3. 20 year old car - I would look for intake hose cracks /splitting. Many times you can hear an exhaust leak (phish-phish noise).
  4. Possible causes: – Incorrect signal from MAF sensor – Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled – Exhaust system leaking
  5. You didn't read the Lost Radio Code FAQ "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  6. Porsche wiring harnesses are custom built to the cars specs. So you need to find one with the same or more specs than your car to have any hope of straight forward swap. Too many wires is much better than not enough.
  7. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread.
  8. 986 552 335 01 01C "Boxster S" logo in switch plate trim
