  1. Correct end guards for seat rails.
  2. It os actually John (not Jeff).
  3. Check the pulleys if they wobble they should be replaced.
  4. Removing and Installing the drive belt 1. Remove engine cover. 2. Remove front air guide hose. Note: Only remove the drive belt when it is cold. 1. Mark the running direction -arrow- of the drive belt with chalk. 2. Relieve the tension on the drive belt by loosening the tensioner using a suitable tool. To relieve tension on the drive belt, turn the tensioner clockwise. 3. Remove the drive belt and lock the tensioner using locking pin T10060 A. Install in reverse order.
  5. Clear the codes take the car for a short drive (at least 10 minutes) - then recheck the fault codes.
  6. Two beeps mean that there is more than one zone open or that the controller has failed. I would go after the door lock first. BTW... the immobilizer/alarm box did not get wet through plugged top drains or other? If it did get wet then you will need a new or rebuilt one as water damage will lead to future failures as thing corrode.
  7. Yes on central locking switch. But historically these are usually mechanical failures in the door lock. If the gas lock in is intact is the receiver in the gas lid there?
  8. Check to see if the lock pin is broken off. If so, I did a DIY on how to replace that here:
  9. Possible cause of fault • Central locking switch faulty • Short circuit to ground/open circuit in wiring between the alarm system control module, central locking switch or door locks • Driver's/passenger's door lock faulty • Control module faulty
  10. Fault 60 - Central locking limit position - Locked not reached Most likely a mechanical failure in the door locking mechanism (in the door that does not lock). You can also listen for audible click when you lock the door - try using the key to lock. Do a search here for door lock repairs.
  11. I suggest you clear the codes - operate the doors and locks again - and see what codes you get then.
  12. You are correct - it changed in 2009 and I missed it.
  13. Tinted or untinted? Many US/Canada cars had slightly tinted side windows.
  14. PM me your VIN and I will look it up.
