  1. Not likely injectors - there would be mixture issues and fault codes. Not to mention rough running.
  2. It is always helpful to give the exact model and year of your car.
  3. Most common ticking sounds are the hydraulic valve lifters. Sometimes and oil change to a lighter oil followed by an oil change back to 0W-40 will help clean the dirt and debris out.
  4. Please post in "Wanted" section of Classifieds. Thank you. This topic is closed.
  5. No. 2001 GT2 Muffler (item 5)
  6. DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. This topic is now closed.
  7. Not much in the service manual for your issue. Here is a parts diagram that should help some.
  8. DO NOT START A NEW TOPIC FOR A LOST RADIO CODE. DO NOT EMAIL ADMINS. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. This topic is closed.
  9. No - it sounds sweet.
  10. Most likely problems are a bad ignition switch or bad headlight switch. Wiggle the key and see if makes a difference - if not, then try the same with the headlight switch. A third possibility is that someone removed the instrument cluster and did not get all the connectors properly reseated.
  11. Try for 4: 4393 Try for 5: 3401
