  1. Porsche parts list does not show any available black headlight kits for any cars prior to 2011. Sorry.
  2. Exact model and year please...
  3. Did you use the Lost Radio Code FAQ procedure to get your serial number? If not then please follow the procedure and re-post. If you did then chances are your radio has not been repaired by Becker but has been repaired by some 3rd party. In that case I can not help you.
  4. Please read the Lost Radio Code FAQ FIRST before posting - then post in the one thread. This topic is now closed.
  5. Try keeping all the screws loose or half-tight until you can align each side.
  6. Several different pumps and pulleys were used. They all attach via bolts. You still might need a puller after the bolts are removed.
  7. Photo and model year would be helpful. Thanks.
  8. Did you use the Lost Radio Code FAQ procedure to get your serial number? If not then please follow the procedure and re-post. If you did then chances are your radio has not been repaired by Becker but has been repaired by some 3rd party. In that case I can not help you.
  9. CDC is Compact Disc Changer. I need the radio serial number.
  10. What (exactly) is the radio model number?
  11. You did not say this was a Traffic Pro... Try 63636
