  1. Or... the bracket that hold the solenoid is cracked. That happened on 996TT a few times.
  2. P0021 Possible fault causes - Dynamic driving style when oil level is near minimum (oil foaming) - Solenoid hydraulic valve faulty => (e.g. mechanical fault or dirt in the oil circuit) - Oil pressure too low => (e.g. due to oil dilution, oil thickening, wrong oil quality, fault in oil pressure control or oil pump) - Intake camshaft adjuster faulty - Camshaft stuck (incorrect or faulty installation)
  3. Try 9027
  4. Try 8727
  5. Bumper Plugs can do that... Rear Center Console - 996/986 BUMPERPLUGS.COM Custom paint-matched or contrasting console, finished in 19 stage factory chemistry to brighten up Porsche interior.
  6. You could try either Becker or Siemens repair centers.
  7. Is that the serial number as displayed on the unit or the serial tag on the top or back? The serial tag may not be correct if the unit has ever been repaired - even by Becker. If a third party ever repaired they didn't reset serial number properly - if that is the case I can't help you.
  8. Try 5147
  9. Porsche alarms were option on Boxster. M535 is the correct control unit. The alarm horn should be down to the right of the battery and is just the horn. Sometimes it is hard to see.
  10. Try 8937
  11. Try 1097
  12. Try 0631
  13. Try 8468
  14. Try 5024
  15. Try 5210
  16. Give your dealer/OPC your VIN and they can tell you which key fob can be programmed to your car.
  17. From the Lost Radio Code FAQ... "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  18. Try 8356
  19. Try 0709
  20. From the Lost Radio Code FAQ... "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  21. Try 0565
  22. Try 4718
  23. Try 5193 and Try 1312
  24. Try 0758
  25. Try 1549
