  1. My understanding is fan control is from the DME through the relays. Relay location is left front kick panel.
  2. Yes, the light switch can cause that problem as well the socket where the headlight plugs in could also cause issue if broken or corroded.
  3. Clutch pedal microswitch can be checked with an ohmmeter. The crankshaft position sensor (CPS) can be checked with a Porsche specific fault reader. Both can cause the issue you are having.
