  1. Please do post the same request multiple times. Start by reading the Lost Radio Code FAQ
  2. Please clear all fault codes - start the engine let it idle, drive it around the block - then re-read any fault codes (including pending codes) you have and report them here.
  3. :welcome: Are you sure the ignition switch did not have a wire come loose when re-installing? Have you checked the battery for both specific gravity and load testing? Does this only happen when the lights are on?
  4. (click to enlarge) Relay Support 2 - position 9 is the Secondary Air Relay.
  5. From the factory maintenance schedule... "On vehicles with annual mileages of less than 9,000 mls (15,000 km), an annual maintenance must be carried out once a year."
  6. Model year of car please... You did check the fuses? F23 in the right fuse box?
  7. Lost Radio Codes are only answered in one thread. Read the Lost Radio Code FAQ and follow the directions. This topic is now closed
  8. You have not - you are asking about a fairly common problem and there are many threads on it. It is always best to search first as others have likely had the same issue.
  9. You do not need to remove the engine. The throttle body and center intake need come off as well as the alternator. Then it is easy. Porsche book time for this is just under 2 hours.
  10. Exact model year of your car please - and US/Canada version or RoW?
  11. The title of the service manual section I took the diagram from is "91 13 19 Removing and installing GPS antenna − as of MY 2005". The radio antenna(s) are mounted to that panel -- I believe the GPS antenna is under that panel.
  12. In the cowl panel. Make sure it didn't just get un-plugged when they installed the windshield.
  13. If you If you do not have the 40 digit codes that came with your key(s) then you will never be able to program them in - you would need to buy new keys.
  14. Hi guys, Here I am again! Can you please help me with this? Thank you! Try 1296
