  1. For SN # 15005323 try 2891 For SN # Y5060963 try 8709
  2. Yes, in 2007 the front fenders are the same on the GT3 RS and the 997TT. (This is not true for 2010 and newer GT3 RS).
  3. Yes - the positioning is the same for all 996TT model years.
  4. :welcome: The exact model and year of your car would be helpful...
  5. Air quality sensor for vehicles with air conditioning (click to enlarge)
  6. particlewave - I am sorry but you are wrong. Here is the functional description of how it works from the Boxster (986) Service Technik. (click to enlarge) And... just to clarify I am a moderator as well I am the site founder and owner. and RFM is volunteer moderator and former Porsche factory employee.
  7. I thought you said the Porsche part (from your wing) did not fit? 999 703 140 41 Rubber buffer -- US MSRP $2.34 each
  8. Your are likely going to have to find out who made the wing and contact then then.
  9. Sorry, my mistake... try 0210
  10. Great -- some actual photos of screens would be great.
  11. Have a look at this: http://www.renntech.org/forums/topic/22621-instrument-cluster-lcd-not-illuminated-in-986/?p=118046
  12. Even a DIY Video here: http://www.renntech.org/forums/videos/view-85-remove-and-polish-porsche-996-headlights/
  13. Fault 0907 -- Load management operation on vehicle electrical system/DME control module Possible causes of fault - 'no display' Loads are/were switched off temporarily. The load management operation was enabled because of undervoltage. Most common cause battery replacement. Clear it and it should not come back (unless there is some other cause like a pinched or broken wire).
  14. Ah yes... Porsche needs to learn that sales people do not buy cars - customers buy cars. That is the kind of thinking that led to "all cars should be black" -- 100 years ago.
  15. Hmm... I do not like the idea of making the Cayenne look like the Macan. Each should have their own look.
  16. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM?s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
