  1. Please read the Lost Radio Code FAQ - "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  2. Those are available to all of our Contributing Members. To become a contributing member simply click the Donate button at the top right of any page and follow the instructions.
  3. :welcome: Start by removing and cleaning the MAF with a good air flow sensor cleaner (do not use other products). Clear the codes and see if any come back.
  4. Re-training involves holding the button for open until the window opens all the way and continue holding for an additional 10 seconds. Do the same for window down. Each window and sunroof are trained separately. If the window drops 1/2 inch when you activate the the door handle then you are getting power.
  5. :welcome: Have you changed the battery recently? If so, did you re-train the sunroof and windows?
  6. All these codes are power related - make sure you have checked all fuses (with an ohm meter). As well check the power connectors to the CDR-24.
  7. Did you read the Lost Radio Code FAQ - I think not. Porsche (Becker radios only)
