  1. I sent you a PM.
  2. Ok - one more USA/Canada car or RoW?
  3. 2002 and 2003 are (very) different . Please tell us the exact model year of your car...
  4. I believe he is correct - the pulley is just a pulley and the bearing is in the pump housing. Looks like a new pump is in order.
  5. Is there a good link to the DIY how to change power steering pump? Did you read the 2nd post on this page? -- that is direct from the Porsche Service Manual.
  6. Yes, all are replaceable (Alternator, AC, and power steering. Use an engine stethoscope to find the location of the noise.
  7. Check your amp (if you have one) fuse and all conenctions Start a different thread if you are still having problems
  8. Do a search here and in the DIY Tutorials sections - lots of broken regulator questions and answers.
  9. You already posted this once - so I will close this topic.
  10. Please read the Lost Radio Code FAQ for the radios we can help with.
  11. Sorry, that is what you need the Porsche diagnostic tester for. You will need a shop with a Porsche PIWIS 1 or PIWIS 2 tester.
  12. The nuts just carve a thread into the soft brass of the crest when they are installed. I usually end up just pulling them off with needle nose pliers. The nuts are inexpensive but the crests by gone up by a factor of 10x in the last few years.
  13. Did you follow the procedure in the Lost Radio Code FAQ to get your serial number?
  14. 141 951 253 B Relay -- US MSRP $21.42
  15. Start by following the instructions in the Lost Radio Code FAQ
  16. If you want a part number please send me your VIN via PM - there are so many options it is the only way to get the right number the first time. 955 552 165 00 4X2 Rootwood connector housing -- US MSRP $421.96 Apparently the wood housings are much more expensive. :eek:
  17. If you want a part number please send me your VIN via PM - there are so many options it is the only way to get the right number the first time.
