  1. If you have an engine misfire then you have fault code(s) or pending faults. Either your Durametric needs updating or you need to find a Porsche diagnostic tool.
  2. You need to run full diagnostics on the car using Durametric or a Porsche diagnostic (i.e. PST2, PIWIS, or PIWIS 2). Everything is a guess without fault codes provided by any of these tools.
  3. If a relearn of the window function does work then it is likely a bad microswitch in the door handle. Covered many times here.
  4. I do not know that there is such a resource. Every car can have different options so what comes up is what the car has.
  5. Search is your friend... http://www.renntech.org/forums/topic/38040-auto-door-lock-enable/?p=201253
  6. Yes, try driving the car a few miles - then wait 30 minutes.
  7. Try 0575
  8. Try 8457
  9. Try 4912
  10. Try 0217
  11. Try 7285
  12. Try 0851
  13. Try 0501
  14. Try 8194
  15. Radio serial numbers only have a letter at the start of the serial number - so that is not a valid serial number.
  16. Try 9218
  17. And the Porsche model number of your radio please? Model: 4362 SN: 15002368 Thanks Try 0486
  18. Try 1281
  19. Try 9867 While I was getting info. I entered a code that put radio display to WAIT. Now it will not allow me to enter new code. What now? If you read the Lost Radio Code FAQ you would already know the answer to that...
  20. And the Porsche model number of your radio please?
  21. Try 6876
  22. Try 9867
  23. Try 5320
  24. Could be both a bad microswitch in the door as well as a bad interior sensor. I suggest you clear them all and see what comes back after a few lock - unlock sequences.
