  1. You do know that you click on the image to make it larger or to download it for printing? They work well for me.
  2. Excellence Magazine has a very good Porsche Buyers Guide that you can purchase from them for $14.95 printed or $4.95 download. You can get it here. Beside specs,problem areas, and driving impressions it will include the latest market values.
  3. Please read the Lost Radio Code FAQ
  4. I see you did not read the Lost Radio Code FAQ
  5. Did you see the DIY Tutorials? Air Filter - http://www.renntech.org/forums/tutorials/article/52-air-filter-change-instructions/ Pollen Filter - http://www.renntech.org/forums/tutorials/article/66-pollen-filter-change-instructions/
  6. Please read the Lost Radio Code FAQ and follow the instructions there. This topic is now closed.
  7. Yes, pretty much a direct part replacement. It is best to disconnect the battery and let the engine program re-learn the idle and power curves after the new installation.
  8. Okay, I see now. You can rent or buy a spring compressor or... Attach the top 3 studs and bolts first - then carefully use a bottle jack (or floor jack) to push the bottom of the shock up to the mounting point.
  9. Use the weight of the car to compress the spring -- carefully. I have done this dozens of times.
  10. Lower the car just a tad so that the upper mount will go through. You need a little pre-load.
  11. That serial number looks too short. Please check the serial number useing the method in the Lost Radio Code FAQ
