  1. P0413 Secondary-air solenoid valve driver – open circuit Possible cause of fault - Fuse F50 faulty (fuse carrier on left of dashboard) - Open circuit in voltage supply in secondary-air solenoid valve - Open circuit in ground supply in secondary-air solenoid valve - Secondary-air solenoid valve faulty (resistance too great) - DME control module faulty Always start with the fuse.
  2. IMHO this is a job for a professional wheel shop. Even after you get them off for cleaning and perhaps painting it is the re-assembly and proper torque and proper torque sequence that is of the utmost importance. Plus you will want the wheel checked for trueness balance.
  3. Please post in the proper thread here This thread is now closed.
  4. Search is your friend... http://www.renntech.org/forums/topic/5600-center-console-upper-shelf
  5. Please read the Lost Radio Code FAQ (and follow the directions there) - all your answers are in there.
  6. Step one is battery voltage - both at rest when charging. If that is good then my next step would be the ignition switch.
  7. (click to enlarge)
  8. I do not see any reason why it would not.
  9. You need to clear all codes and then see what comes back. The power supply faults are usually due to a battery change and that same battery change can cause other erroneous faults. Emissions fault codes are found in the Porsche OBD 2 manual for your model. The other systems fault codes are in the service manual for your model.
  10. Are you speaking about the spring compensation plate? If so, it's thickness will be color coded - to the spring tolerance.
  11. I would check in this order: loose or bent heat shield, bad muffler, bad catalytic converter.
  12. Question marks do not work for serial numbers - we must have the complete serial number. Please use the procedure in the Lost Radio Code FAQ to get your serial number.
