  1. I do not think so - even the Panamera has had several (970 based part numbers) for Xenon lights.
  2. All of that kind of detailed information is in TSBs. http://www.renntech.org/forums/tsbs/cayenne/ These are available for viewing to all Contributing Members.
  3. Porsche only sells one harness repair kit for each axle side. For the Left Rear - 996 612 953 01 Repair Kit Harness -- US MSRP $128.89 For the right Rear - 996 612 954 01 Repair Kit Harness -- US MSRP $128.89
  4. http://www.renntech.org/forums/topic/1827-dash-bulbs/?p=8151
  5. To re-learn: press hold window down switch - continue holding for 10 seconds once it reaches all the way down. Do the same for window up - press and hold for 10 seconds. Re-try the window drop - if it still fails then see these other posts... you really need to try a simple search... http://www.renntech.org/forums/topic/11050-power-window-issue/#entry53966 http://www.renntech.org/forums/topic/8248-window-issues/#entry40691 http://www.renntech.org/forums/topic/33954-window-drop-down-issue/ http://www.renntech.org/forums/topic/19348-window-drop-question/ http://www.renntech.org/forums/topic/16876-driver-side-window-not-working-tried-almost-every-solution/#entry84657
  6. If you have an engine misfire then you have fault code(s) or pending faults. Either your Durametric needs updating or you need to find a Porsche diagnostic tool.
  7. You need to run full diagnostics on the car using Durametric or a Porsche diagnostic (i.e. PST2, PIWIS, or PIWIS 2). Everything is a guess without fault codes provided by any of these tools.
  8. If a relearn of the window function does work then it is likely a bad microswitch in the door handle. Covered many times here.
  9. I do not know that there is such a resource. Every car can have different options so what comes up is what the car has.
  10. Search is your friend... http://www.renntech.org/forums/topic/38040-auto-door-lock-enable/?p=201253
  11. Yes, try driving the car a few miles - then wait 30 minutes.
  12. Radio serial numbers only have a letter at the start of the serial number - so that is not a valid serial number.
  13. And the Porsche model number of your radio please? Model: 4362 SN: 15002368 Thanks Try 0486
  14. Try 9867 While I was getting info. I entered a code that put radio display to WAIT. Now it will not allow me to enter new code. What now? If you read the Lost Radio Code FAQ you would already know the answer to that...
