  1. Please read and follow the instructions in the Lost Radio Code FAQ I need your model number too.
  2. We have a 3rd party service (that we have to pay for) that we use for our Contributing Members -- where we can run a look-up for you. PM me your when you are a Contributing Member (Donate here) and I'll run the look-up.
  3. CDC is the CD Changer and it does not require a code. Please read and follow the instructions in the Lost Radio Code FAQ
  4. Wow! - normal should be 40 to 60 ma. You need to start doing some checking - one fuse at a time.
  5. For 6 presets TrafficPro try 22154
  6. Well, there is a rear control unit - that controls those lights. I do not know why it would sense a high resistance (the warning light) like a light was out unless there were a damaged connector or wiring somewhere. It would be very odd for a control unit to only have this problem -- not very likely but I guess possible. PIWIS would be the only sure test.
  7. No Sports-Chrono in the 996 series - 997 series was the first use.
  8. Sounds like either your manual lock has been re-keyed or the locking mechanism in the door is broken.
  9. These are the (only) correct part numbers for Bi-Xenon lights for your model and year car. I hope you are sitting down when you read the pricing... 996 631 059 20 Left complete headlight assembly -- US MSRP $3231.14 996 631 060 20 Right complete headlight assembly -- US MSRP $3231.14
  10. The system is sensing high resistance. There is a ground point in each rear tail light - I would check those for corrosion. As well remove the license plate bulbs and make sure they and their sockets are clean of any corrosion.
  11. According to the VIN that car came with the Aluminum package not one of the wood packages. So it would appear the wood was added later - and you would need to tell me what wood (Rootwood, Olive Ash, etc.) it is to be able help you.
  12. What is the problem you are having and are there any fault codes?
