  1. I do not think US/Canada cars were given this option. Likely local laws.
  2. I would not worry about the gateway fault for now. Are you sure the battery is good? Have it load tested if you have not.
  3. Please read the Lost Radio Code FAQ "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  4. Perhaps a loose or poor connection on the oil pressure sender. This is a known weak area.
  5. Perhaps the Speed gong is set on your car as the spoiler (working or not) does not generate any beeps.
  6. Arena Red Pearl (97-99) / Arena Red Metallic (00 on) Water-based paints (84S) and Conventional paints (84R). US/Canada cars all got water-based paint (per EPA rules).
  7. Obviously you did not read the Lost Radio Code FAQ did you... ;)
  8. Please read the Lost Radio Code FAQ What is the model number of your radio?
  9. What is your front wheel width and offset?
  10. I have not seen the prep TSB for 2015 models - it is not yet showing up in PIWIS TSI. In the past some hardware and programming were both required.
