  1. Exact model and year of your car please? And... is the a RoW or US/Canada car?
  2. All 996 normally aspirated models are e-gas with one exception the the 1999 C2.
  3. When it won't start you need to run a DME only test. Then report back all fault codes (also please specify whether they are P-codes or Porsche DTC codes - as there is some numbering overlap).
  4. Please read and follow the procedure in the Lost Radio Code FAQ. We need your radio serial number. (not your VIN).
  5. Some of the front end and read end harnesses can be replaced (if needed) without replacing the whole car's harness. Any idea what caused the damage?
  6. Did you follow the procedure in the Lost Radio Code FAQ?
  7. Did you have a look at all the TSBs on hard top noises and latches? http://www.renntech.org/forums/tsbs/carrera/
  8. Moved to the proper forum. Did you do a search (in this forum) as this has been discussed before?
  9. Durametric, PIWIS, or PIWIS 2 can all do diagnostics on the HVAC system. If you do not have access to one of these find a shop that does. Everything else is just guesses or expensive dis-assembly that may not be required.
  10. 997 504 825 04 Left Stone Guard Film -- US MSRP $49.68 997 504 826 04 Right Stone Guard Film -- US MSRP $49.68
  11. Please read my post above we can not help you here.
  12. Well, you obviously did not read the Lost Radio Code FAQ. If you did you would have read: "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  13. P0011 Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 1 – Signal Implausible P0139 Oxygen Sensor Aging After TWC, Bank 1 - Above Limit P0159 Oxygen Sensor Aging After TWC, Bank 2 - Above Limit P0234 Boost Pressure Control Limit Exceeded - Above Limit P0441 Fuel tank ventilation system above limit value/below limit value P2243 Oxygen Sensor Ahead of Catalytic Converter, Bank 1 – Nernst Voltage Line – Open Circuit P2247 Oxygen Sensor Ahead of Catalytic Converter, Bank 2 – Nernst Voltage Line – Open Circuit I would clear all of these - re-start the car, drive a few blocks -- then re-read any fault codes.
  14. The MY2002 wiring diagram implies at the speakers.
