  1. Only one rear fog light - by design. Nothing wrong with the rear fog light.
  2. OPC = Official Porsche Center (same as Porsche dealer)
  3. You did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  4. Try 9828
  5. Try 6954
  6. Try 1047
  7. If this is true then leaving the engine compartment open at idle the light should go off.
  8. Bad sensor in the coolant tank?
  9. Sometimes it is further up behind the front bumper. Also something the may help is to have a 2nd person push gently on the front hood log area while you activate the release. If that does not work then you might have to remove the front bumper cover - which means replacing some parts and if not done correctly the front bumper can be damaged. So - good luck on that.
  10. Try 8426
  11. Try 9698
  12. Sorry, I have no idea. Please read the Lost Radio Code FAQ "Which radios fitted to Porsche can have their unlock code recovered through serial number? - CR-220/CDR-220 - Becker - CR-210/CDR-210 - Becker - Traffic Pro NAV/CD - Becker"
  13. Try 5467
  14. Try 0242
  15. History has shown the Tip to be sensitive to worn-out or dirty ATF. It can cause all kinds of erratic operation. Make sure the fill is done properly also with the fill level checked at the proper ATF temperature. That would be the place I would start. Everything else will require special diagnostic tools and more cost.
  16. Has the ATF been changed recently? Was Porsche spec ATF used? Most Tip issues are weak or failed solenoids.
  17. Try 8508
  18. Try 4368
  19. It does not look like Porsche sells this as a separate part so your best bet would be a auto salvage yard.
  20. #9 is the part number that you mentioned.
  21. It is always helpful if you tell us the exact model and year of your car. And what the problem is.
