  1. The air filter comes with oil on it - sometimes too much oil. Cleaning the MAF with MAF cleaner will usually save the MAF.
  2. Sounds like your K&N filter was depositing oil on the MAF. That is a common problem with oiled filters and over oiling.
  3. Any beeps (single or double beeps) when you lock the car?
  4. No that wire goes to your amp. The alarm wire should be a separate wire.
  5. Thanks. Could that be a contributor to my issue? Yes, depending on whether the aftermarket radio is sending a signal on that wire. Either way it is best to disconnect that wire and tape it.
  6. A single beep signifies an open zone - so that is likely your aftermarket radio. If you had a CDR220 prior to replacement you will need to remove and tape the brown wire with the blue stripe.
  7. Please READ the Lost Radio code FAQ "CDR-23 (or later): These radios do not have a security code - that is, not that the user enters. These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  8. OBD II codes are emissions codes and have nothing to do with alarm fault codes. You need Durametric or a Porsche diagnostic tool (like a PST2 or PIWiS) to read alarm fault codes. It could be a bad sun sensor but the alarm code readout would say for sure.
  9. It would be helpful if you told us the exact model and year of your car.
  10. Sometimes you can feel the carpet with your hand. If it feels wet, damp, or rough (like carpet that got wet) then you need to remove the seat for further inspection. ALWAYS disconnect the battery before removing a seat or you will get an airbag light fault when you disconnect the cables.
  11. From the rear of the car SmarTop is in the bottom left connector. If not SmartTop then it is either something else, or faulty control unit, or a DIY mod of unknown origin.
  12. You can check to see if it has SmarTop or a similar device attached at the main connector. If, then just disconnect it and plug the main cable back in.
  13. So if you got two beeps that indicates an alarm fault - that somehow fixed itself. Intermittent faults can be difficult to track down because you have to catch them in the act. Any chance the alarm/central locking control box (under the drivers seat on LHD cars) got wet? If so, it needs to removed opened and inspected to see if it can be cleaned and repaired - or replaced.
  14. Yes, doesn't work on my TapaTalk either - I will send them a bug report.
  15. :welcome: Have you cleared the codes and then seen if they call come back or?
  16. Do you like puzzles? Most of the Porsche connectors have locking mechanisms. As I recall this one slides (pink part) up to release the connector.
  17. Durametric or Porsche PS2 or PIWIS will tell you exactly where the fault(s) are. There is a lot of work (and cost) with guessing.
  18. JFP in PA is correct. If these procedures actually worked I think there would be a lot of stolen Porsche's. I have actually programmed (new) keys to cars using a PST2 and PIWIS - there are IPAS codes needed as well as original unique key number code. Only 4 keys can be programmed at any one time - and to overwrite one of the 4 key codes you need the original key and the unique key number code. Those procedures may have worked on older cars but not on 996 or newer Porsches.
  19. I just did a TapaTalk update - see if that took care of it.
  20. Sometimes you can get lucky with a long hook tool. Grab the metal cable -- not any wiring.
  21. Yes, it should have a manual release cable near the left rear tail light. Use a hook to grab it behind the wheel well liner.
