  1. What scan tool did you use to get those codes? They are not on my lists.
  2. Hope you all got the towing option for the trailer you will need... I just use my insurance card and have 'em tow it home ;)
  3. I do not recall needing IPAS codes for that just a PST2 or PIWIS. But if you do you may need both - the alarm control works that way.
  4. Two screws from the bottom side as I recall.
  5. Did you read this? http://www.renntech.org/forums/topic/2930-glovebox-handle/?p=13752
  6. Do you have a CEL? Does the engine run rough? If not, I would ignore it.
  7. It means that if you buy the fuel pump for a MY2002 or newer then it will have too high a fuel pressure and could cause damage.
  8. Make sure the part is for MY2001 and older cars as the fuel system changed to ventless return flow system in 2002. The ventless runs at a higher pressure.
  9. I think that is a good choice. Everyone please be aware this thread is about MANUAL transmission Cayenne GTS. Not many of those in the US/Canada area.
  10. Part numbers can start with any number or letters (they had to run out of numbers someday). i.e. 000, 999, N, 95B, etc., etc. etc.
  11. I have removed your double and triple posts on the same subject - please do not make multiple posts on the same subject. Thanks!
  12. if you have dual exhaust tips use this: 955 111 108 30 Clamp ( dual exhaust tips) -- US MSRP $21.89 If you have a quad tip exhaust let me know as their are 4 clamps and they are designated for left or right sides.
  13. Please post the exact model and year of your car - thanks.
  14. With all due respect you are mistaken. We use the same model numbering/labeling that Porsche uses in ALL their documentation. (click to enlarge)
  15. Is your Durametric software up to date? Best try a PST2 or PIWiS otherwise as the chirp definitely signifies an alarm fault.
  16. It is always helpful to give us the exact model and year of your car. The 996 series had two different cup holders.
  17. We only do option code look-ups for Contributing Members since those require a 3rd party service that we must pay for.
