  1. There is a DIY Tutorial for removing and replacing the headlight switch... http://www.renntech.org/forums/tutorials/article/258-replacing-the-headlight-switch-in-the-dash/
  2. You obviously did not read the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  3. My 2009 (US) Order Guide shows "Sea Blue" -- so likely just a difference in country order guides naming.
  4. :welcome: No - no such model.
  5. For your misfire you can switch the spark plug to a different cylinder and see if the misfire follows it. If not try the same thing with the coil pack. That should tell you where the problem most likely is.
  6. :welcome: It goes to a sensor that reports the engine compartment air temperature. The sensor mounts in a metal holder and they sometimes get bumped and fall out. Just put it back in the holder and you are done.
  7. Model of the radio please? MODEL: Becker CDR-220 TYPE: 4462 Try 5820
  8. Model of the radio please?
  9. That depends on the model year of the car. On the later model cars you have code both the cluster and the DME -- and it does not show until the switch or stalk is installed. Yes, I still live in Roseville.
  10. Exact model and year of your car please...
  11. The smaller the bolt the easier to snap - trust me I have tried the shortcut and failed. Get or borrow a inlb torque wrench.
