  1. Seriously 3 posts -- 3 radio codes requests. Please tell me more...
  2. Does your have AC? Different part if it does.
  3. Could be a bad ground or an alternator going bad. Measure the voltage across the battery before and after the lights. Report it here.
  4. Try 0623 Perhaps you might want to consider a donation?
  5. Porsche parts list does not show a part number for just the clips. You might want to try a salvage yard or you will need to buy the whole sensor cover (about $137 in Metropol Blue).
  6. Seriously 7 posts -- 7 radio codes requests. Please tell me more...
  7. It is likely that your secondary air injection pump faulty/stuck or there is a short in the wiring.
  8. From the service manual: "Symptom Squeaking noises from around the spoiler drive when extending and/or retracting the rear spoiler. Causes and remedial action Squeaking noises can occur when extending and/or retracting the rear spoiler as a result of dust or if the upper part of the spoiler is too tight. Remedial action Clean the spoiler guides, seal bores using strips of adhesive tape and loosen the spoiler drive."
  9. WKD 944 020 90 Owner Manual can still be purchased new from Porsche. About $72.
  10. Sorry, we only support the radios stated in the Lost Radio code FAQ.
  11. Has someone taken the instrument cluster out recently? If so I would suspect they did not get all the cable locking connectors back in place properly. There are three large cable connectors that must of locked into place securely.
  12. Fault 25 - start by checking fuse E1. (4th row down and first fuse on the left. In my experience fault 47 (with fault 61) is usually caused by a mechanical failure in one of the door locks. You can tell which one using a Durametric or Porsche PIWIS tester. You can also test the microswitches in the door(s) using these diagnostic tools.
  13. Try 9875 Lost Radio Code FAQ
