  1. Sorry, no other way to program a new key other than with a Porsche PIWIS - and the proper codes from Porsche.
  2. Did you use a Porsche PIWIS to program the keys?
  3. Check the cable from the battery to the starter for corrosion - do the same for the chassis ground.
  4. Porsche does not list them as separate parts. I think a salvage yard might be a good choice.
  5. P1123 Oxygen Sensing Adaptation Area 1 (Cylinders 1 . 3) - Lean Threshold P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 • 6) - Lean Threshold This is telling you your fuel mixture is too rich. So rich the DME can not compensate for it. Possible causes: - Fuel pressure too high. - Fuel injector leaking. - EVAP canister purge valve open. The most common cause we have seen here is the canister purge valve is open.
  6. Sensors/transmitters are inside the wheels. The receiver is the control unit that then communicates with the PCM/radio and the instrument cluster via CAN (network).
  7. Strut work should always be done in axle pairs. That is... do both sides.
  8. I would also suspect condensation moisture (water) in the gas tank. For that I think HEET would be a better product as a water removal additive. It can't hurt.
  9. Only a Durametric or Porsche PST2, or PIWIS can clear an airbag fault. Disconnecting the battery will not clear passenger safety faults.
  10. You can try sending a PM to the author as his original images were on a 3rd party site rather than uploaded here.
  11. Yes, there are sensors (with battery) inside each wheel.
  12. There is a control unit here But depending on the age of your car I think the sensor/battery (one per wheel) is likely bad. These seem to last only 5 or 6 years before replacement.
  13. You need to READ the Lost Radio Code FAQ - then post in the proper thread. This topic is now closed.
