  1. From the Lost Radio Code FAQ... "Can you give me a code for my PCM? These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM code is from a dealer/OPC."
  2. The burnt resistor is not normal. You could try replacing just that - but you may need a new board.
  3. Short circuit to B+ You need no shorts in the alarm, door locks, and windows for them all to work - and you do have a fault. They all run through the same control unit. You also need a good battery.
  4. Really? I gave that to you last year. Perhaps you should write it down this time.
  5. Fault 34 -- Passenger compartment monitoring sensor - Short circuit to B+ or faulty
  6. I sent you a PM.
  7. The airbag fault code should tell you which device (driver or passenger buckle, or control unit.
  8. Could be a bad electrical connection in the buckle. Fairly common - more so as these cars age.
  9. You did not read the Lost Radio Code FAQ... "CDR-23 (or later):These radios do not have a security code - that is, not that the user enters.These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  10. One beep means you have one or more alarm zones open. Two beeps means you have an alarm system fault. Durametric or PIWIS can immediately identify which zone or component has failed. Without the diagnostic everything is just expensive guesses.
  11. It is always best if you tell us the exact model and year of your car.
  12. I'm pretty tied up until the second week of April - so perhaps someone else is free before then.
  13. This site does not distribute copyrighted materials. WKD 951 020 07 PCM 2 Manual -- US MSRP $17.45 at your local dealer.
  14. Did you try looking here?
  15. Sounds like someone has bypassed the clutch switch. Look for a jumper or perhaps someone tie wrapped the switch to always open.
  16. It is always best if you can give folks your car's exact model and year.
  17. You need to re-train the windows. Hold the Down button until the window is all the way down - then hold it for 10 more seconds. Do the same for window up and you are done. One-touch should work again.
