  1. Due to copyright laws, these can not be duplicated online here (or elsewhere). You can buy these from an OPC for pretty reasonable prices. PCM manuals run under 10 USD and Operating Manuals run about 25-30 USD.
  2. Please go back and read the Lost Radio Code FAQ... it will answer your questions
  3. Just drive the car - the adaption ranges will set to your driving style.
  4. That is the longest serial number I have ever seen on a Becker/Porsche radio - I hope it is correct. Try 4828
  5. Yes, but you will likely need a Porsche diagnostic tool to see the airbag operating hours.
  6. I would get both fuel pump outputs tested.
  7. Any good Porsche shop should have Porsche wire harness pin removal (and replacement) tools.
  8. If the check engine light is flashing that means there is a emissions fault that would damage the catalytic converters. When the light flashes the car should not be driven (according to Porsche). The shop should use a Porsche diagnostic tool on the car - if you have a CEL or flashing CEL then there must be one or more fault codes.
  9. The crank position sensor is on the flywheel housing and is triggered (magnetically) by the teeth on the flywheel. 1. Remove connector. Connect an ohmmeter to CPS sensor connector, pins 1 and 2. Display at 20 °C: 0.8 - 1.0 k ohms 2. Connect an ohmmeter to CKP sensor connector, pins 1 and 3. Display: infinite ohms If either test fails you need to replace the CPS.
  10. Check the CPS (Crankshaft Position Sensor) too.
  11. From the Porsche Technical Book on operation...
  12. The speed is controlled by the DME - which means the DME runs it as fast as needed to properly control the cooling. In the older cars, you only had high speed or low speed -- so now you have variable speed control. The variable speed will minimize temperature spiking between settings.
  13. Please read the Lost Radio Code FAQ and for the procedure there to post in the proper place. This thread is now closed.
  14. With the ignition to the "on" position - hold the clock adjustment button turned to the left for about 5 seconds.
