  1. From the Guidelines/Rules, you agreed to when you registered here... "Copyrighted material:By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this bulletin board. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted." This topic is now closed.
  2. Which MAF are you using? The one from the 987, 996, or 986? They are all different and the software needs to know which one is in use.
  3. To add to what Ahsai said - check that the o-ring int he oil filler cap is present and in good shape.
  4. Good job - most issues like this are obvious with a simple inspection.
  5. You would also need IPAS codes for your car;s DME as well as IPAS codes for the donor car.
  6. Please re-read the board Rules/Guidelines that you agreed to when you registered. "Copyrighted material:By registering here you agree not to post (or link to) any copyrighted material unless the copyright is owned by you or by this bulletin board. Repeat offenders will be banned from this site and their accounts, as well as the offending material, will be deleted."
