  1. Find someone local near you with Durametric, or a PST2, or a PIWIS tester. Might just cost you a beer or two.
  2. I would disconnect it and put it someplace safe while you work on the regulator. Resetting an airbag fault is easy with the right software tool. I once saw a shop tech lean an airbag against a wall while he worked on the window regulator - the airbag slipped down the wall and went off. The customer got a new airbag.
  3. Possibly just dirty or needs lubrication?
  4. 911 618 102 01 is the seat belt relay. I'm still looking on old wiring diagrams for the wires.
  5. As you sit in the car the #1 cylinder will be the furthest to the front on the right side (same for V6 or V8).
  6. Exact model year of the car, please?
  7. On the button to the right of the speedometer (clock on it). With the ignition on, hold the button turned to the left for about 5 seconds. Done.
  8. From the Lost Radio Code FAQ... "Can you give me a code for my PCM?These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/OPC."
  9. The DME will need to be reprogrammed for the e-throttle. Only a Porsche PST2 or PIWIS can do this (to my knowledge).
  10. The CD is copyrighted material - discussion closed.
  11. Your OPC should sell a CD to upgrade - about $250 US. There is no other (legal) way to do firmware updates.
  12. Please read the Lost Radio Code FAQ for how to obtain your radios serial number electronically.
