  1. Two-alarm chirps mean there is an alarm fault. Normally Porsche's just flash the lights on lock and unlock. You need to check the alarm system with a Porsche specific tester for faults.
  2. Hmm... I think you might need a PIWIS 2 or PIWIS 3 then. Sorry...
  3. Have you got the latest Durametric software - 6.5.5.5?
  4. Thank you -- but please don't post the same video multiple times...
  5. The lower you go with the coilovers the harsher the ride. Even at the highest setting, it will still be a bit rougher than stock.
  6. I would go coilovers and adjust the ride height to your liking. Neither of those shock options is "comfort" rated.
  7. For a 1976 911 and 911 Targa - Yes. I did not see a different listing for 911 S Targa. I do not know about RoW cars but US cars for that year were all 911 S. I owned one.
  8. That is just the engine type. Typically Porsche changed that number every year or so when improvements were made. Realize that the 2.7-liter air-cooled engine could easily be modified to 3 (or more) liter engines. Sometimes folks do not realize this until they take it apart and see a different crankshaft or cylinders. So, what shipped with the car is not always what is in the car today...
  9. Engine code - 911.81 HP -165 Liters - 2.7
  10. I already answered your request... above.
  11. View this tutorial 2017 Macan S, GTS, Turbo DIY Oil Change Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. Parts you will need: 1 ea 0PB-115-466 Oil Filter (updated) 1 ea 946 107 322 75 Oil Filter Housing O-Ring 1 ea 900 123 152 30 Drain Plug Seal 9 ea Mobil 1 0W-40 or equal Tools you will need: Tire ramps or jack/jack stands T20 Torx driver Trim, panel tool 8 mm Allen wrench or Allen hex socket Oil filter wrench with 36 mm cap socket Author Loren Category Macan (95B) - Maintenance Submitted 05/24/2018 05:01 PM Updated 03/19/2021 10:14 AM
  12. Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. Parts you will need: 1 ea 0PB-115-466 Oil Filter (updated) 1 ea 946 107 322 75 Oil Filter Housing O-Ring 1 ea 900 123 152 30 Drain Plug Seal 9 ea Mobil 1 0W-40 or equal Tools you will need: Tire ramps or jack/jack stands T20 Torx driver Trim, panel tool 8 mm Allen wrench or Allen hex socket Oil filter wrench with 36 mm cap socket Socket wrench 9-quart oil catch pan Torque wrench Note: If your car has Air Suspension and Level Control - then before jacking the car switch it OFF. 1. Raise the front of the car (both sides) using a jack and supporting with jack stands. 2. Remove the engine cover. 3. Remove the oil cap and inspect the sealing rubber ring on the cap (replace if torn or damaged). 4. Remove the underbody engine cover. 15 - T20 Torx screws (items 1 and 2) and remove the 2 - expansion rivets (items 3) (using a trim tool is the easiest for these). 5. Remove the drain plug and drain the oil. 6. Remove the oil filter canister using the 36mm cap socket. Then remove the old oil filter. 7. Clean the filter housing with shop towels, as well clean the drain plug put the new crush washer in place. Clean the filter canister and install the new o-ring (use a small amount of new oil to lube the new o-ring). 8. Re-install the oil filter canister with the new oil filter inside (some pressure may be needed to push the new filter over the engine mount). Tighten the canister to 19 ft-lb. Re-install the drain plug with the new sealing washer and tighten to 33 ft-lb. 9. Add 8.45 quarts of new oil. Refit the oil filler cap. Re-install the engine cover. 10. Start the engine and let it idle for a few minutes while checking for leaks. If no leaks then shut off the engine and re-install the underbody cover (yes, all 17 fasteners again). Lower the car and remove the jack stands. 11. Use a PIWIS 2 (or PIWIS 3) to reset the oil change reminder. A few other Porsche specialty scan tools may be able to do this now (or in the future). Note: If your car has Air Suspension and Level Control - then switch it back ON. That's it you are done. Download the PDF version of this: 2017 Macan S, GTS, Turbo DIY Oil Change.pdf
  13. If the Brown / Black wire is actually Black with Yellow stripe then that is the correct connection.
  14. Are you sure you are pulling the emergency release cable hard enough? Sometimes it helps to have someone press down on the engine lid (over the latch) while trying to release it.
