  1. Yes (I guessed your radio model).
  2. Then chances are that your radio was repaired by someone other than Becker. The radio serial number changes with any repair and they did not use the Becker algorithm -- so I can not help you. Sorry.
  3. Then chances are that your radio was repaired by someone other than Becker. The radio serial number changes with any repair and they did not use the Becker algorithm -- so I can not help you. Sorry.
  4. If you are talking factory wheels - then probably not. The front and rear wheel offsets are different and I doubt the front wheel clearing the brake rotor or suspension when placed on the rear.
  5. Sometimes it is a hose and sometimes it is the tank - only inspection will tell. Remove the front tire and wheel well liner and you should see everything.
  6. Short answer - yes. You can download the complete option list here:
  7. The cats would be just ahead of the muffler. Some owners replaced the cats with straight pipes that looked the same as cats.
  8. Have someone press down (gently) as you release the lid.
  9. Sounds like it may have gotten misaligned. If that is the case it will be a bit of a pain to realign and tighten down again. See my DIY for replacing the fuel door solenoid...
  10. Has this car got a tune (modified DME program)?
  11. 64H08022 = original build -1987 type - 930.25 liters - 3.2 HP - 218 note - speical model with catalytic convertor
  12. Did you follow the procedure in the Lost Radio Code FAQ to get the correct serial number?
