  1. 1) Probably. You may need to re-route the wires through the bundle ties. 2) Probably. You may need to re-route the wires through the bundle ties. 3) The MY02 and newer cars center console is one piece (older cars were 3 piece). You will need to insert a plastic spatula into each lower side of the cover and gently press out. Then work you way up the side (bottom to top) to the central vent. Inside the center vent is a metal clip. Press in on the clip using a small screwdriver. Press and hold screwdriver upwards and simultaneously pull out the central vent with the cover.
  2. Ahh... my DSL ISP went bankrupt this last week... so I moved everything to a new site/provider. You can find it at: http://www.garlic.com/~ljcook/indexDIY.html I do plan to move all of the content from my DIY site to the forum here in the DIY section... when I get time ;)
  3. Try calling or emailing Larry Reynolds at Car Care Specialties. He usually has really great advice and has right products to solve almost any difficult paint problem.
  4. Andy, Thank you very much for the donation! :clapping: Your support will help keep this board running as we grow. Please not your title now says "Contributing Member" signifying to other your commitment to this site and the activities here. THANKS AGAIN! :D
  5. Paul, Thanks for the contribution! :clapping: Donations like yours will help keep the site running as it grows and uses more bandwidth and disk space. This site is not much about titles (or stars for that matter) and for the most part they are turned off. But the moderating team and I have decided on a couple of exceptions so... please note your title now says "Contributing Member". Hopefully, this will signify to others your personal commitment to the board and the activities here. Once again -- THANK YOU! On the second subject my DSL ISP (DSLDesigns) went bankrupt so my service had to be changed over to another ISP. Verizon was pretty good and the switch only took 24 hours... the bad news was that I was down for 4 days not knowing my ISP had gone out of business :eek: Anyway, I'm back and so are my DIY pages (and email). I plan to bring all the content from my DIY site into RennTech.org but in the mean time you can find it here: My DIY stuff
  6. I've yet to confirm this in the MY03 schematics (since they are not published yet) but a number of owners have mentioned that this works. I did find this obscure comment in the MY03 Owners Manual: "The convertible top may only be actuated during driving on even surfaces and at wind speeds of less than 50 mph (80 km/h)."
  7. I've yet to confirm this in the MY03 schematics (since they are not published yet) but a number of owners have mentioned that this works. I did find this obscure comment in the MY03 Owners Manual: "The convertible top may only be actuated during driving on even surfaces and at wind speeds of less than 50 mph (80 km/h)."
  8. VERRRRY NIIIIICCE!!! :D :D :D
  9. If you mean item 8 in the diagram... the part number is: 999 591 712 40 Rivet 6.0 x 12.0
  10. I am not a big fan of changing one suspension componnet without change the other affected parts (i.e shocks, bumpstops, etc.). So, perhaps you want someone elses opinion? ;) If you want to lower the car that can be done with just spring changes but anything lower than 3/4 to 1 inch will make the engine block more vunerable to damage (high curbs, rocks, etc.) and you may have some problems with fairly normal driveways. Porsche sells and recommends two wheel spacer combinations. The first combo is four 5 mm spacers on all four wheels. This is sold as a kit that includes longer wheel bolts and longer wheels locks. All GT3's use these spacers. The second option is 5 mm spacers on the front and 17 mm spacers on the rear. If you ever have to run the spare tire the 17 mm spacer must be removed to mount the spare (the 5 mm are ok). 5 mm spacer kit
  11. Hey, thanks to all... but remember that it's all of you that make this forum successful. I just lit the fire :cheers:
  12. Thanks! Spring spacers or wheel spacers? If I may, there is a greart article on Porsche tuned suspension in PCA Panorama. IMHO I think it is kind of a required reading before making any major decisions on suspension changes. You can find the article at: 996 Standard and Sport Suspensions Analyzed
  13. As long as it is DOT 4 (not DOT 3 or synthetic DOT 5) it should be okay. Porsche does not recommend synthetic brake fluids (I do not know why). I change back and forth with ATE Gold (Type200) and ATE Super Blue. This is great for street and pretty good for light track useage. Both have a high dry boiling point (536 degrees) and a high wet boiling point (392 degrees), but without being excessively hygroscopic (these fluids do not readily absorb moisture like most high performance fluids). They are the same fluid with the same properties one is yellowish gold and the other is blue. This allows easy viewing when bleeding to see when the new fluid is through the system. The are other higher temp fluids that are available... but for the most part if you are changing every 3-4 DE's then you should be okay. About $12 liter and you will need about 1 liter per change. Other good fluids are: Castrol SRF Brake Fluid (dry boiling point is at 590 degrees, wet boiling point of 518 degrees) -- Do not mix with any other fluids. You must do a complete flush with this fluid. About $65 liter :eek: Motul 600 (dry boiling point 585 degrees and a wet boiling point 421 degrees) -- Synthetic. Do not mix with any other fluids. You must do a complete flush with this fluid. About $12 liter AP-600 (dry boiling point 590 degrees, wet boiling point 410 degrees) -- Do not mix with any other fluids. You must do a complete flush with this fluid. About $18 liter
  14. Is your car a Targa? I see an extra piece for the Targa (911 511 127 00) but not listed for coupe. I don't remember this on my 76 911S coupe...
  15. Factory spacers should be balanced. They are screwed onto the hub so they become part of it and should maintain the balance. If you are using aftermarket spacers I would be tempted to have the wheel balanced on the car (good shops can still do this when needed). That way the wheel weight would offset any balance issues. All JMHO... as I've never seen one out of balance. ;)
  16. Mike, The Porsche 5 mm spacer kit uses 5 mm longer wheel bolts (911 GT3, P/N: 996 361 203 90). These GT3 wheel bolts are marked with GT or with a red color on the head surface of the bolt head, or the rotating spherical cap is galvanized in red. The distance from the bolt head flange (not the rounded washer) to the bolt tip is approx. 50 mm. The standard wheel bolts, P/N: 996 361 203 00 are approx. 45 mm. I'm sure you can order them separately. 5 mm spacer kit
  17. If you click on either donate button, then when the PayPal page comes up click on the "If you have never paid through PayPal, Click Here" button and it will allow you to use VISA or MasterCard. THANKS! :cheers:
  18. If you put the car in neutral and press the clutch in and out, do you still hear it? If so, it is likely the clutch throw out bearing.
  19. Fuel pressure line? or vacuum line? I emailed you some info on the fuel pressure lines.
  20. Thanks for the site comments... :D IMHO... It's not about bleeding it about changing the brake fluid. High temps can cause brake fluid to break down and absorb moisture. When the moisture in the fluid gets hot it vaporizes and become a gas... not good for braking performance. Depending on the number of hot laps at a DE I would suggest every 2-4 events and DE's are the toughest on brakes. Brake fluid is cheap (about $12 liter) and changing it is only about an hour once you get the hang of it. A lot of folks go back and forth with the ATE Gold and ATE Super Blue that way they can easily tell when they have bleed through the system. Both ATE Gold and ATE Super Blue have the same chemical properties so there is no advantage to one over the other (a misconception by some since ATE call Super Blue "Racing" fluid). There are several other brake fluids on the market so use what you feel comfortable with. If you want to protect your warranty then make sure use a DOT 4 brake fluid (not DOT 3 or DOT 5 synthetics). You won't need a lift (although if you had access to one it would make it faster). You just need to jack up each corner at a time. See my DIY for the exact bleeding sequence and don't forget there are 2 bleed screws on each caliper (total of 8 per car).
  21. Whoohoo! Looks great Don! :clapping: :clapping: :clapping: The crests and silver on the backs of the seats is a super look too!
  22. I agree with Jeff that if the system has not been drained then you don't need to do anything special for PSM or Traction Control. You may want to bleed the clutch though. It is not very hard and you can find details at this link: Brake/Clutch Fluid Change and Bleeding Instructions
  23. Courtesy of Nasa Racer Pete (used with his permission) - posted by Loren Well, there I was...backing into a parking space against a curb and I was in a hurry and I heard it...SCRAPE! One fraction of a second...barely moving. Got out and looked at the rim...OOOOOOWWWWW! Well, no need to fear...I've done this enough times to have a easy way to do home repairs with a few simple items. Note that this ONLY covers light scuffs, this isn't meant to be used to repair a DAMAGED wheel or one where the scuffs cause significant damage to the rim. This is only for those annoying superficial scuffs like happened to me more times than I care to admit. Now there are PLENTY of GOOD services which can do this for VERY reasonable money...most folks will happily do this but I'm inpatient and have the free time (generally) to spend a couple of hours doing this and it REALLY takes the edge off donking my wheels when I know I can simply fix it myself. So if you are interested...here's what you need: I have a can of scratch-filler primer, the WURTH wheel paint and clear (got mine at Performance Products), some paint thinner, Bondo spot putty (or equivalent), sand paper and some 240 and 400 grit sandpaper (if you are REALLY anal...get some 600 grit). Step 1. Clean...clean...clean...and did I mention CLEAN! This is one of the most important steps. Use paint thinner to THOROUGHLY clean the ENTIRE area around the damage...you need to get ANY wax or polish or anything off the wheel...I'm going to remind you EVERY step...I probably end up wiping down these surfaces 10 or more times before painting...if you don’t do this, the rest is pointless. Also, we want to work ONLY on the area that's damaged...don't go nuts and try to paint half your wheel on the car...for this technique to succeed we want to sand and paint the area only IMMEDIATELY around the damage. 2. Sand and Putty I like to START by masking the tire from the wheel...get the masking tape WELL behind the rim. Next, sand the area to a nice "feather" with 240 grit sandpaper and wipe some spot putty on. IMPORTANT...this ENTIRE project will work best if the wheel is in the sun and its a nice warm day...the drying time of spot putty is minutes but if it's cold or damp, this project is likely to not work out too well. Remember...keep your sanding to the IMMEDIATE area around the damage. Trust me on this. So once you've done the first round of putty, switch to the finer of your sandpaper (400 grit in my case) and sand and putty until it FEELS and LOOKS flush. Note that I use the paper wrapped around a piece of wood to make a flat sanding block. It's best to sand with a flat block to get the smoothest finish: Note that up to this point...including waiting 5 to 10 minutes between coats of putty that the whole project has taken about 40 minutes. 4. Masking and primering: Okay, here's where a bit of laziness is going to create an entire new clay-bar project. This metallic paint will GET EVERYWHERE. I'm talking permanently attached to the fender on the opposite corner of the car...mask CAREFULLY and COVER THE WHOLE CAR with a sheet or equivalent. I've used the thick scratch-filler primer and sanded it and put a bit more putty on. Note that this is the first place where I use the NASA technique. Immediately after I spray the primer (or paint) I clean ALL the overspray off the spokes of the wheel (clean rag and paint thinner) and the area around the inside of the rim...I do NOT want to try to get paint to smoothly adhere to the entire wheel! We just want to paint the REPAIR. Only the clear coat will be sprayed without wiping off the overspray. Wait for the primer to fully dry and lightly sand it with 400 or 600 grit sandpaper. 5. Painting VITAL: READ THE CAN...if you try to use this paint in cold temperatures (or in damp conditions) it’s going to be a mess...shake the can for a minute at LEAST and push the spray nozzle as you sweep across and release at the end. This is roughly the distance I used the can from the wheel...I HIGHLY recommend painting some scrap something to get used to the distances and thickness this paint sprays. Now we SHOULD be nearly done BUT (as always) Pete got inpatient and sprayed the clear WAY too soon and lifted the paint and messed it all up. This is NO BIGGIE...take a deep breath, get out your rag and the paint thinner and take it all off. The thinner I used did not eat into the primer so I simply cleaned the wheel (again) and got to respray the silver. Here’s the paint lifting because of the clear being sprayed too soon. okay, fast forward a few minutes...I had to roll the car forward a bit to keep it in the sun and I had cleaned (and let fully dry) the wheel and RE-sprayed the silver. Now I’m using the NASA technique on the silver paint and CAREFULLY removing the overspray: AND here’s the nicely painted wheel. I’m going to not be an idiot and let the paint dry OVERNIGHT (like I knew i should) and do the clear coat tomorrow. (edit June 14, 2004 added local hosting of images as Nasa Racers hosting was down - Loren)
  24. Home Curb-Rash Repair Courtesy of Nasa Racer Pete (used with his permission) - posted by Loren Well, there I was...backing into a parking space against a curb and I was in a hurry and I heard it...SCRAPE! One fraction of a second...barely moving. Got out and looked at the rim...OOOOOOWWWWW! Well, no need to fear...I've done this enough times to have a easy way to do home repairs with a few simple items. Note that this ONLY covers light scuffs, this isn't meant to be used to repair a DAMAGED wheel or one where the Author Loren Category Carrera (996) - Common Fixes and Repairs Submitted 06/27/2003 10:09 PM
  25. Cool! Thanks Don :clapping: I can build all of my former Porsches there.
