  1. There are a few things that can cause this. One is a carbon buildup inside the air intake butterfly - I use a bottle Chevron's Pro Guard Fuel Injector Cleaner (Techron) about every two to three months to clean that stuff out. A second possibility is dirty contacts on the throttle positioning sensor (egas). Those are the most common -- other than a loose vacuum hose ;)
  2. Yes. Your paint code is on the options sticker under the front hood and your options code sticker in the manual. Arctic Silver is either L92U or L92T (U is water based paint and T is oil based).
  3. You will need to look at the color code on the new springs. If it is the same as the old springs then you do not need any spacer change (they are the same tolerance). If they are different then you will need to measure the thickness of the spacer as you will need the other one (since there are only two sizes). The TT Service Manual has the color codes but I do not have TT Service Manual. The spacers are the same regardless of US. RoW, or even X73.
  4. Page 174 of your owners manual will show you how to remove the headlight housing using the tool supplied in your toolkit (behind the spare in the front trunk). Page 177 will show you which socket has the parking bulb. Should be about a 5 minute job. :D
  5. I doubt it - Gert sells primarily Porsche parts. You will need to email Gert for exact part numbers as I do not know the part numbers in his package. Everything in the front is the same for MY02 and MY03 unless you have the X73 package. In the rear everything is the same for MY02 and My03 (again unless you have the X73 package) -- as long as you are putting a 6 speed rear springs on a 6 speed and not a Tiptronic (or visa versa). No, they are the same part numbers. Front bump stop is 996 343 301 02 - same as US version. Rear bump stop is 996 333 105 03 - same as US version. The compensating spacers are based on the tolerance color code on your springs (this is a separate code from the version color stripes). For the RoW TT rear springs there is a 0.4 mm spacer (996 333 511 03) or 0.5 mm spacer (996 333 511 02). For the front there is a 3.0 mm spacer (996 343 525 00) or a 6.5 mm spacer (996 343 525 01). Front Springs are gold/white. Rear springs are gold/white for 6 speed and gold/red for Tiptronic. I do not have shock color codes.
  6. I sent you another TSB on newer Hardtop Locks...
  7. The OEM fill varies according to my sources. The Mobil PTX is a synthetic as is the Shell Transaxle. 000 043 204 20 Mobil (Mobilube PTX) – 20 liter container 000 043 204 19 Shell (Transaxle) – 20 liter container 999 917 546 00 Shell (Transaxle) – 1 liter container
  8. There are at least two PCM2 software updates. Have your dealer upload the latest software to your PCM2 with their PST2 tool.
  9. In a factory (or dealer) installed PSE there are two modes of operation. First in normal operation the sport sound is on (open) except between 30-45 MPH. This cutoff is based on the speedometer A signal from the instrument cluster. My understanding is that this is a requirement for some European countries the have quiet city zones (i.e. Switzerland). The second mode is the switch which allow the driver to close (or shut off) the sport sound at any time. Finally, if the electronic and vacuum equipment is not installed then the sport exhaust sound will always be on.
  10. The Sears Diehard is available in an 850 CCA.
  11. Thanks, this looks good! A couple of questions... Do you have any photos? This is the rollbar not the rollcage right? Rollbar Rollcage
  12. Going back to stock would be the most elegant solution. You might even find someone that wants to trade for the PSE (plus cash I assume). Just make sure you get stock mufflers for an 02 or later so that your exhaust tips will line up right.
  13. I'll be there as long as it does not rain hard. ;)
  14. Loren
    New member
    :welcome:
  15. Yes, your private registered address. I can not send attachments to personal (board) messages.
  16. I sent you a private email with the slider trim removal instructions.
  17. I can not say that for sure. But you need a body shop to paint them anyway so they can likely make them fit. The numbers I gave you are the individual side skirts. You will see the full listing in the instructions I sent you. No. Again, you'll see (in the instructions) that the adhesive is separate from the aerokit parts.
  18. The older Aerokit Cup style side skirts are held on with epoxy using adhesive kit 000 044 000 37. The newer style Aerokit Cup II use only double-sided tape as they clip over the existing skirts. Here is the parts list from the Aerokit Cup (older one) for just the side skirts. Side Member Panel Part Number Qty. Description 996 559 983 00 G2X 1 Left-hand side member panel, primed 996 559 984 00 G2X 1 Right-hand side member panel, primed n/a 2 Retaining strip n/a 6 Templates 1, 2 and 3; left and right (3 ea. per side) n/a 22 Countersunk sheetmetal screw, 4.8 x 13 n/a 16 U-clip n/a 1 Left-hand adhesive film n/a 1 Right-hand adhesive film n/a 2 Sheetmetal nut; St 4.8 Part numbers are not given as they are part of the larger (complete) kit. If you need the install instructions for both kits let me know and I will email them to you.
  19. Craig is talking about a TSB for MY99 (and older) cars where they updated the upper strut mount (with bearing) and backup ring with a newer design. You should already have that newer design... but it still could have a problem.
  20. Changing the oil in a 996 is a 15 minute job (except for the drain and drip time). Porsche does not recommend a 30W oil for their cars. With that said you are likely okay until your next oil change as long as the temps don't get into the 90's. For your climate you could go with any of the 5W-50 without a problem - but any of the oils on the list should be okay. Before this service bulletin came out Porsche recommended only Mobil 1 15W-50 for our cars. That is what is in my car right now.
  21. Could be a loose support mount or ball-bearing housing or the spacer not fully seated. Your car is pretty new to be having this sort of problem so I would consider taking it back to whomever installed the RoW M030 and asking them to check their work.
  22. According to My-Porsche.com these are no longer available. You can down a free copy of the MY03 manual (which will be pretty close) from Suncoast Porsche at Suncoast Manuals
