  1. This is what I use on my laptop. Nothing fancy - nothing expensive. $122 Car Code OBD-II
  2. Is this the standard cap? If so try 996 361 505 11 9A1.
  3. PST2 is the Porsche Diagnostic and Programming tool.
  4. Yes, just ask your dealer to turn on the OBC using his PST2. Temperature display is the default so even if you don't have the stalk to control the other OBC functions you will still get the temperature.
  5. Yes. I have installed these on a friends car and they work fine. PSE does not change any of the geometry, if they fit your current muffler/rear bumper then they will mount the same way on the PSE.
  6. Can you tell me a little more about what it would include?
  7. 986 552 995 09 designates a rear center console painted to an external color... so you would need to specify color (this is the same as factory option XME). Likewise the 000 044 802 25 kit (I believe) specifies ash tray etc. in arctic silver as it is a Tequment package.
  8. It's the prewired phone connector. Brown = Ground Red / Green = Switched 12 volts Green / Black = Unswitched 12 volts Yellow / Black = Telephone Mute (Jeff's pic)
  9. A little more info.... The MY03 Cayenne's (until April 28th, 2003) all had Auxilary Batteries and TSB 1/03 2706 describes how to install it. After that Porsche moved the Auxilary Battery to an option status (Option J2C) for MY04 cars (TSB 2/03 2706). So the good news/bad news is that if you have a MY03 you likely got the 2nd battery included and the MY04's will only have it (and the wiring harness) if it was ordered as an option.
  10. 1. Lever off locking button with an a hard plastic tool (to prevent scratches). The locking button must be pressed so that the pipe section can be inserted between the shift lever and the locking button. To do this, turn the ignition key to "1" position. 2. Remove the compression spring (1) and spring clip (2)and pull off the selector knob. Install is the reverse. Make sure you fit the conical compression spring with the small diameter facing the guide peg.
  11. Yes. You use the complete tailpipe from where it attaches to the muffler pipe. See my PSE install here
  12. Sounds like MAF sensor to me but it would be nice to know what the codes were.
  13. No, not for the new GT3 at this time. You could go the route that rockitman did (Europipe muffler/race cat) here
  14. Parts are $1558.80 (see Porsche Parts at Dealer Cost above). If you just install the mufflers (open all the time) you are looking at about 1 hour labor. If you install all the electronics and vacuum stuff then it is an additional 5 to 9 hours. Porsche quotes 10 hours total in the their install TSB. Here in Calif we (unfortunately) expect to pay $80 - $100 (USD) per hour for labor.
  15. Umm... I think they want the speedometer A wire which is used by all Porsche Nav systems. I don't know the color code on the Cayenne but it comes directly off the instrument cluster.
  16. With all due respect I really don't think you want to take the dash out... (Jeff's pic)
  17. You care to share any of that info? While my own troubleshooting would lead me to agree with the technicians diagnosis that the bleeder seat is damaged, it would be interesting to know if the TSB pertains to the slave cylinder componet or elsewhere in the system. While I believe the dealership will now be resolve my problem, a TSB that affects the slave cylinder might help him cover it under warranty and lessen the possibility of hard feelings towards me for making such a big deal over my situation. Depending on the model year there are several "clutch squeaks". Most are pedal or pedal return spring related and vary with different versions of the pedals and springs used over the years. There is also one for a squeak in the transmission clutch bell housing that is throwout bearing release related. To my knowledge there are no TSBs for the clutch slave cylinder.
  18. From what I can tell from the parts list - yes. It appears that the 000 number is a kit and 996 number just the one large part.
  19. 911 095 933 20 37W Midnight Blue Metallic This is the two stage applicator with primer/color and clear varnish. I am not aware of any spray can touch up paint for Porsches. In most cases you would need to buy a small can of your paint from a paint supply shop (or have a shop mix some for you) spray the area and then put several clear coats on top.
  20. Dated Feburary 16, 2004 And the second one (MY2004 only)... Dated February 16, 2004 And a third one for MY2003 only... Dated Feburary 16, 2004
  21. Yes, but it will lower your car too. Make sure you can live with a car that is 3/4 inch lower in front and 1/2 inch in the rear. It doesn't sound like much but if you already have trouble in some driveways...
  22. I believe that part 1 is a complete center console with ashtray, side panels , etc. in arctic silver. And, part 2 is just the rear console piece (without ashtray, side panels etc.).
  23. $42,057.42 Retail :D
  24. The radio for the CGT is in (at least) 3 pieces. There is a base unit (that may be hidden in the car), a control unit (knobs etc.) and a (remote) display unit for the console. I don't have prices just part numbers. I'll send you what I have.
  25. 19" wheels take the starshaped center caps. 955 361 303 02 9A1 Silver starshaped center caps (4 needed).
