  1. For a GT2? TT? or TT with Aerokit?
  2. From the instrument cluster Diagnostic Section of the Service Manual: This makes sense that both would go on if the ABS/ASR signal was not there. I would check fuse B9 (second row from the top ninth fuse from the left) (15A) first. After that it would have to be a broken wire or bad ABS control module.
  3. P0150 indicates Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Intercore Short Circuit or Limited Voltage Increase. That would be on the driver's side in a Boxster.
  4. I have 18" wheels. I have to look into the wheel carriers. Doesn't someone sell turbo brake upgrade kits? Both EVO and FVD sell upgrade kits. You WILL need new hub carriers - TT's are 4WD and your C2 is not.
  5. Most folks use the Wurth Silver followed by the Wurth Clear coat and the match is really good. Have a look at Nasa Racer Pete's DIY here
  6. You can get power or dash light power from other switches. I think Scouser just used PSM since it was close.
  7. I don't know that the lights have anything to do with the early build car updates - I always thought it was to better distinguish the Carrera from the Boxster. Certainly the late MY99 build cars have a number of small problems fixed (i.e. coolant expansion tank, gas cap and oil filler cap seals, o-rings on oil return pipes, clutch boost spring, etc.). Changes are made during production all the time so cars that were early builds still may have many of the later build fixes. That and/or the dealer may have fixed most of them. Your car's build date can be found a sticker on the driver's door frame.
  8. There is a DIY here that Contributing Member Scouser wrote up (with pics).
  9. That is a right muffler only for a MY01 or older Carrera.
  10. Only the early MY99 (US) cars had amber lens(es) (not bulbs). My June 99 build Carrera and all later Carrera's had clear (H2) headlights and tail lights. I upgraded to Litronics have which always been clear.
  11. More than you will ever want to know... DuPont Krytox®
  12. That is the plastic cover that supposed to go in the black plastic cover over your firewall/battery/firewall. It is supposed to allow you to read the VIN easier. :lol: Mine fell off a long time ago... it's in my toolbox now.
  13. Unless you can find a used one on eBay or at a salvage yard you are looking at: 996 653 101 03 EFR CLIMATE CONTROL UNIT $617.14 (retail Dec 2004)
  14. 986 605 115 01 Throttle Body $332.85 (retail as of Dec 2004)
  15. See the Brake/Clutch Bleeding DIY here
  16. If so, the information has not yet hit http://www-odi.nhtsa.dot.gov/cars/problems/recalls/ or http://www.consumerreports.org/main/search/recalls.jsp
  17. Sent you a PM...
  18. Looks like it is Basalt Black Metallic (unless it is marked wrong)...
  19. 2.5, 2.7, or 3.2 liter?
  20. Do mean the INSIDE mirror? or the OUTSIDE mirrors? (Porsche sells both)
  21. For MY99 to MY01 you will need: Item 1 - 986 552 113 02 A10 Carpet Lining (black) Item 2 - 999 507 533 02 Clamps (2 or 4 I think) Item 3 - 986 552 513 02 A10 Left Carpet Cover (black) Item 3 - 986 552 514 02 A10 Right Carpet Cover (black) Item 5 - 986 552 241 02 A03 Cover (black plastic) or Item 5 - 986 552 127 00 A11 Cover in Leather (black)
  22. They are not factory (or optional) wheels for the 996 series. I do not know the brand.
