  1. Cayenne Maintenance Checklists have been added to the Maintenance Checklists section.
  2. Yes, it is worldwide. Previously they spec'ed Mobil 1 15W-50. But they took that off the list a couple years ago.
  3. Looks like they are on the seat fuses Left 44 and Left 45. It would seem that only one side would be out at a time though?
  4. Yes, that is the lift point I use. It is as close to a frame member as you are going to find. What bears the weight when you get a little airborne going over a hill? and when the car lands? I guess I would say the same cross member. If you don't feel comfortable lifting the car there, or at the engine, then I don't know where you can lift it at.
  5. Yes, it is not a true dry sump system. Overfilling will cause stress on seals and the crankcase ventilation system (oil separator, venting bellows, etc.).
  6. Most folks use 3M adhesive remover, a little dental floss and in rare cases a little heat from a hair dryer. Keep the heat away from the 3M adhesive remover!
  7. 996 505 311 04 G2X is a standard front bumper for a MY99 - MY01 Carrera. 996 505 980 02 G2X is the GT3 (mk1)/Aerokit bumper.
  8. I actually go further back and jack on the rear suspension cross brace (you will need a low profile jack for this). I use a jack with a hockey puck on it so it isn't metal to metal contact.
  9. I've done this several times on my wife's Jeep. Unfortunately the design on the Jeep allows leaves and other crud to fall inside the fresh air intake. Porsches are much better with the pollen filter stopping most of it. I use Lysol and turn the heat up as far as it will go (with the windows down). That way you cook and kill all the stuff that is growing in there.
  10. Two things come to mind. One is that the water level sensor (in the coolant tank) sends a message to the cluster (and DME) to turn the fan on. I would think if this were the case then you would also see a flashing coolant warning light. Secondly, there is a relay that turns on engine compartment purge fan. The relay is in position 8 (part number 141 951 253 B ) on the DME relay panel.
  11. We did this for all Carrera variations so it's time we added for the Boxster's too. Measure the position of the logo with a measuring tape according to the model variant and affix it to the rear lid. Logo Boxster -- 3 A dimension X = 285 mm and Y = 45 mm Logo Boxster S -- 3 A in connection with the letter S dimension X = 245 mm and Y = 45 mm Logo S -- 3 B dimension Z = 20 mm and V = 40 mm
  12. Mobil 1 0W-40
  13. Could be the horn bushings. http://www.renntech.org/forums/index.php?showtopic=1728
  14. CAN was used a little more in DME 7.2 for DME, Tiptronic and PSM. Later in DME 7.8 it was used quite a bit more (Tiptronic, DME, PSM, Instrument Cluster (various certain functions).
  15. 000 044 900 70 PCM2 Retrofit Kit -- Retail $4363.77 (as of Oct 2005) and you still need a fiber optic cable for your cars options. Check with the folks at Sunset Imports (Porsche Parts at Dealer Cost) for a better price.
  16. There is no CAN connection on the instrument cluster. On a MY99 car the only place the two CAN wires go is to a Tiptronic (if so optioned - M249). Looks like you will need to take your connection from the DME. Blue and Grey is correct.
  17. Both the buckles and and underseat wiring connectors corrode. Porsche issued a TSB that replaces the buckles and connector contacts with gold plated connections and ground point is modified. To do the fix yourself you will need pin removal tools and experience with a soldering iron. Takes an experienced tech about 2-3 hours. The 5 page TSB is available for viewing here by Contributing Members.
  18. Are you sure it is in the steering wheel and not the front struts? There is a TSB for steering noises that are caused by a slippage in the front strut mounts. The fix is to replaced the strut mounts with a newer design. There is a second TSB for clicking noises that requires replacement of the upper strut mount bearing too.
  19. Here is what I have based on the Oct 2005 MSRP dealer price list and Nov 2005 parts list: Clutch disk - 997 116 013 10 - $251.03 Pressure plate - 996 116 027 02 - $298.12 Release bearing - 996 116 080 04 - $126.44 Clutch guide tube - 996 116 087 01 - $35.11 Total Parts: $709.70 7 hours seems a little over estimated also (IMHO). I would be more apt to believe 3-4 hours tops. Even the service manual quotes 350 TU (or 3 hours 50 minutes). The clutch guide tube would (should?) have been replaced free had you complained of "creaking noises" under warranty.
  20. Try PMing the DIY author or get your parts list (including fiber optic cable) and then I can look up retail (MSRP).
  21. It does not matter either method will work fine. Porsche believes the electronic method is accurate - witness the newer cars don't have the dipstick anymore. I usually measure the oil after it warm using the graphic display on the cluster. I would only add oil if you have one or two bars showing - and then I would only add 1/2 liter (or 1/2 quart).
  22. http://www.renntech.org/forums/index.php?showtopic=3404
  23. Is the o-ring in the oil cap? You will need to take the car to Autozone or another shop that will read the codes for free. Then report back here what (all) the codes are.
  24. Yes, only black. 996 555 557 10 A03 Cover (black) -- Retail $44.92 (as of Oct 2005)
