  1. It would be best to get a readout from a PST2 or PIWIS tester to confirm where the fault is. There are special precautions when replacing the triggering control box. The key must be removed, the battery disconnected - then wait for at least 1 minute. The service manual says the control box is held in place with "shear-off nuts" and to use Porsche tool 9259 socket wrench insert. The airbag control box should be at the bottom of the center console (near the telephone prep). The new trigging unit must be "locked" using as PST2 or PIWIS tester once it is installed. For all these reasons you may want a certified Porsche tech to do this.
  2. Porsche specs 17" and 18" wheels for the MY99 Carrera in matched sets. The front fenders are rolled from the factory. Tires sizes spec will veery with wheel sizes. 17" Porsche spec wheels: Front: 7 x 17 offset 50/55 mm Rear: 9 x 17 offset 55 mm 18" Porsche spec wheels: Front: 7.5 x 18 offset 50 mm Rear: 10 x 18 offset 65 mm or Front: 8 x 18 offset 50/52 mm Rear: 10 x 18 offset 65 mm or Front: 8 x 18 offset 50/52 mm Rear: 11 x 18 offset 63 mm Only a couple of tire brands will fit the last option (11" rears) without rubbing.
  3. P1124 and P1126 (opposite sides of the engine) both show an air leak that the DME can not adjust for. The evap canister fault (P0446) could be a loose gas gap (or bad seal) or could be a bad purge valve. I would check all the vacuum lines on the engine. I would also take the air cleaner off and see if the idle valve and throttle butterfly are gummed up with carbon. Yet another possibility could be a cracked or leaking oil filler hose or even oil seperator. Any smoke from the engine? Also, where are you located?
  4. For a new exhaust - yes, that is not uncommon. Take the car on a 30 minute drive and all or most of that should be gone.
  5. Why would a new engine with a warranty be bad? Get a PPI if you have any concerns.
  6. You can find both versions of the PSE install instructions in the Carrera (996) TSB section. TSB 2601 for both.
  7. Perhaps - but I don't know for sure. I got the pics from a dealer memo about the new option.
  8. Either 996.505.980.03.G2X or 996.505.980.02.G2X will work.
  9. Item 15 - 996.107.150.61 Filler Tube -- Retail $32.72 (as of February 2006) Item 16 - 999.707.348.40 O-ring 42 x 4 -- Retail $6.40 (as of February 2006) use with o-ring 000.043.205.10 Grease -- Retail $31.02 (as of February 2006) -- much more than you need, perhaps someone in the shop will give you a small amount.
  10. Yes, please post your questions here rather than emailing me -- that's why we have this site. There is a lot collective knowledge here - not just me. Try emailing Gert@carnewal.com or alex@sharkwerks.com - both sell the clear and smoked lenses for Porsches.
  11. Yes, you could come off the fuse panel. Radio Shack has jumper/tap that makes it very easy (Radio Shack #270-1204). This is a jumper but you get the idea... (Images courtesy of Yoseif)
  12. You realize the seat memory and seat heater uses two fuses (per seat)? - A6 and E3 for the left hand seat. Other than a broken wire there is just the seat heater pads and the switch.
  13. They are all listed in the TSB section... 7/05 9112 PCM2.1 and Navigation Unit- System Connection Software Release, Model Level B -- Jun 23, 2005 12/05 9110 PCM2.1 Navigation Update -- Sep 7, 2005 2/05 9110 PCM2.1 System Complaints and Repairs -- Aug 11, 2005
  14. Yes, that will work but you won't know what the problem is and it won't correct the problem. Autozone will read your code for free. Upper right corner of the page click on "Reviews"
  15. What do you mean? larger? If so, just click on the image.
  16. You are correct the Mk1 GT3 did not use the CAN bus at all. From what I can tell even on the MY99-01 996 the CAN bus was only used for Tiptronic to DME communication. Starting in MY02 (DME 7.8) they starting putting more on the CAN bus.
  17. 980.637.244.01
  18. Loren. I have the same problem but only when I activate the headlight washers. I just noticed that one of my healight washing jets is not working (driver's side), and the other comes up but does not jet any fluid out. I do endu up with a puddle of fluid in between the front driver's side wheen and the end of the front right quarter paner, near the driver's door. Do you have an idea on where I might start looking for loose hoses, etc.? Thanks Loren. MY02 and newer headlight washers are different from the earlier ones. Here is a diagram...
  19. That is where the tank and pump(s) are. Could be a hose or could be a cracked tank. You will need to remove the wheel and wheelwell liner to see what is going on.
  20. MSRP $17.05 - as of February 2006
  21. I think the button is glued on. I've heard of a couple falling off - but it seems the dealer just glued them back on.
  22. If your car has the anti-dazzle (inside) rearview mirror there is switched 12 volts on that - Black/Orange wire.
  23. Just remember that the darker you get the windows tinted the darker it will be at night - so pedestrians, bicycles and other vehicles will be harder to see.
